Old 03-26-2012, 10:05 PM   #1
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Project Underfunded / next phase - LSx carb'd to LSx efi
Well its time for the next phase on my project. I had a guy interested in a domain I had and we could never come together on a price. Finally discussed trades...next thing I know my truck is changing from carb to efi!
Just as well....the wife wouldn't ride with me with the Holley keeping the exhaust rich. Says she smells like shes been riding a motorcycle when we get out of it. So...here we go!
The plan? Remove all the carb related gear....carb and intake, MSD box and harness, the low pressure fuel system, etc. and then install new fuel system, efi intake and related components, efi harness, sensors, etc. then the plan is to find a 4L80-e to upgrade to. So here we go with a bunch of parts again.
how it sat:
once cleaned up (and pained maybe) this is replacing the carb intake:
and the harness I got (with a pre-tuned e38 ecm and a tcm)....is AWESOME!
if you're wondering its a custom Nelson Performance stand alone harness...not a cut up OEM harness. This thing is sweet! Labeled up, shrink wrapped, new relays and fuse panel, and even has that fiber weave covering that looks sort of like s.s. flex hose but black. I saw the custom pegged up super long table they're made on so I'm guessing its going to fit great. I have a walbro 255, GM filter/reg, and lots of new AN fittings and s.s. hose being delivered tomorrow.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-26-2012, 10:09 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Project Underfunded / next phase - LSx carb'd to LSx efi
Sweet! TBSS intake? You'll never go back...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-26-2012, 10:31 PM   #3
85burb
85burb's Avatar
A moment of silence please........... Ok were done. Cant wait to see if it runs any different. Would be perfict time for a electronic trans....
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-26-2012, 10:38 PM   #4
mooseknuckles
mooseknuckles's Avatar
this is gonna be sweet!...
mooseknuckles is offline   Reply With Quote
Old 03-26-2012, 10:38 PM   #5
68GMCCustom
thanks guys
not a TBSS as thats for catheral port heads. This is a LY6 which is like an iron 6.0L L92 ...instead of aluminum 6.2L.
Kurt -
Old 03-27-2012, 12:19 AM   #6
lt155ruck
lt155ruck's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
lt155ruck is offline   Reply With Quote
Old 03-27-2012, 12:23 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
Kurt,
Did you get the harness direct from Nelson Performance? If so, how much?
Also, what does it need for a accelerator? I have an LQ9 from a 2005 Denali and trying to find a nice harness at a reasonable price.... and I read the e38 ecm doesn't use a separate module to control the accelerator pedal…
Rich
1972 K5 Blazer CST Click HERE
Old 03-27-2012, 01:47 PM   #8
68GMCCustom
mcm...Yes the harness came direct from Nelson Performance. It uses a late model accelerator pedal assembly that just plugs into the harness. Not sure where or what it came from as Nelson Performance provided it. I'm wondering if they have to be removed from a combo pedal assembly? Pic below
As far as the harness price (or the pedal, etc) I can't say as this was all part of a trade we made.
Kurt -
Old 04-03-2012, 10:20 PM   #9
68GMCCustom
Well I guess I'm overdue for an update. Got quite a bit done but didn't have the pics uploaded yet....so I wasn't going to post until I did. !
So...here's carb related gear tear down. Followed by fuel system removal, clean up, intake/tb installation, and getting wiring harness laid in.
pulling it apart. MSD gone, regulator and -8 AN fuel line gone, etc.
intake pulled and things wiped down.
cleaned up, painted and installed efi truck intake and TB.
drained and dropped the tank and installed fitting for fuel return line
walbro 255 pump and GF-822 GM filter/regulator and -6AN s.s. hose/fittings prepped for install with 3/8 NPT to original "primary" fuel filter. I'm keeping the -8AN from the tank to the Trick Flow canister filter. Almost wanted to just connect them with a double female getting rid of the hose...but figured weight/vibration/time would cause an issue... and with a little hose in between things are isolated.
harness layout/install to follow...
Kurt -
Old 04-03-2012, 11:17 PM   #10
68GMCCustom
the "stand alone" custom Harness has all the wire protected with either shrink wrap or that nylon braided wire tubing stuff in various sizes. All the connectors seem to be quality connectors. New 4 circuit fuse panel and multiple relays. 1st class all the way.
He left the end unterminated for the accelerator pedal...so it would be easier to pull the the firewall and I terminate it later. He also provided the pin out of course. Other wires are for DIC/OBD interface.
Drivers side harness all but disappears. Still need to install coolant sender and connect, plus air intake with MAF and connect.
Passenger side laid in great and everything fits great but the MAP sensor. Allen is going to check with Jon (one of his employees and the harnesses daddy ) to determine the best route to correct.
Still have to decide how I'm running pcv/breather hoses...then will likely upgrade them.
Rest of harness is laid down the drivers side fender. I'll mount the ecm and tcm to the inner fender (may build a small box for them) and the relays to the fender. If I decided to go the other direction with it I'd need to run it inside the cab...not something it needs or I wanted to do...so drivers side it will be. I need to rewire a bunch of stuff that's still there... plus finalize the harness install. Should look real nice when complete.
Still looking for a 4L80e/85e to replace the 200-4r. I'm getting quite a stack of parts now... between the 1st build from a '68 body and a '72 chassis and drivetrain, then the 383 upgrade, the carb'd LSx build, and now the carb'd/efi swap. Here's just a few pieces of it.....
still need to install the new fuel system and fuel/return lines. O2 sensors the air intake MAF on the way and to be installed. Also picked up a TB seal and new injector o-ring pack just in case...
I think everything is lining up to start it for the 1st time on "efi" this weekend! Just need to find a brand new 4L85e for like a grand and everything would be great!
Kurt -
Old 04-03-2012, 11:25 PM   #11
85burb
85burb's Avatar
You do amazing work my friend. Looks great. Cant wait to here the differance between carb and factory efi.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-03-2012, 11:32 PM   #12
68GMCCustom
Thanks.....and me too!
Kurt -
Old 04-03-2012, 11:35 PM   #13
85burb
85burb's Avatar
I have had crazy dreams with set of twins in it......Turbos not what everyone else was thinking.....Wife actually caught me looking at factory efi setups. My poor fast efi cant do boost...sad day.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-04-2012, 12:36 AM   #14
Kim57
Kim57's Avatar
Looking real nice.
What kind of paint did you use on the intake?
I want to paint mine and think yours looks real slick.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-04-2012, 07:25 AM   #15
bobvilla67
Looks good Kurt. I'm working in Mckinney now, maybe I can stop by one of these days and take a look at it in person. Last time I was there, the whole truck was disassembled.
Bobby
1968 Custom 10 SWB
1970 2wd Blazer 350/400
1972 K20 292/350
bobvilla67 is offline   Reply With Quote
Old 04-04-2012, 12:44 PM   #16
68GMCCustom
Thanks Kim. Its just some left over Rustoleum High Performance wheel paint in their "Steel" color which is a silver with some sparkles in it like a metallic. Then I hit it with some Valspar gloss clear enamel to protect it.
Yes it was Bobby! Its been put together...and pulled apart again!
At least this time its just some changes and not a complete redo. Still haven't gotten to paint and body yet. Yeah...just let me know when you want to swing by...as you know I'm always here!
Kurt -
Old 04-04-2012, 02:37 PM   #17
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Lol man if you keep making changes in the setup at this rate you'll be able to "speed" tear down a motor faster than any of us.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-04-2012, 04:24 PM   #18
68GMCCustom
LMAO! Well......I'm think I'm trying to make up for years of suppressed hot rodding. You know...wanting to try out everything!
My truck does have a long story regarding all that its been thru since I got it! Well...this changed was unplanned. I'd be keeping it carb'd if this "trade" offer hadn't come up. I thought I was gonna get in cheap...then I bought sensors, hose, fittings, and more and its adding up quick!
That pile of new and barely used parts (along with a Holley Street HP 750, 2 sets of LSx p-rods, set of stock LY6 valve springs, OEM cam and more in my cabinets) is beginning to looks like a pile of money... to buy the new 4L85e I want....
.........and I said I'd never pay for forum use anymore. The top of my User CP page has
Your paid subscription expired on Wed, Feb 02 2011! Click Here to renew it.
I can here it calling my name and saying "clicky-clicky"
Kurt -
Old 04-04-2012, 06:55 PM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
Exactly what I just did. This forum and eBay are funding my swap
-Chris
Old 04-11-2012, 11:07 PM   #20
68GMCCustom
Lots of progress. Fuel system is done...but I need to secure a few things a little better. I spent extra coin and time trying to incorporate some of the 1/2" fuel hard lines and -8 AN s.s. hoses. After getting it all done with various adapters, and finding 3 leaks (at low pressure)... I decided to pull it all, and run a new -6 AN s.s. flex hose to replace it.
Harness got rearranged. I decided to run all the fuses, relays, ecm/tcm to the passenger fender. Have all sensors hooked up except O2 and MAF...should complete that tomorrow.
Bought an inexpensive (well, compared to the others) cold air intake kit for the '99-'07 trucks, plus a 22* 4" tube and extra coupler to work up something to fit... now I'm running that to the drivers side!
Got some rewiring to do, a couple of terminations.....then I can't think of one good reason not to hit the key! Since I have a GoPro now...I suppose I'll set it up to record the event. I'm actually kind of anxious to hear it now...vs w/carb and MSD timing it. get rid of or exaggerate the lope?
I know...............pics.
Kurt -
Old 04-12-2012, 12:23 AM   #21
mcmlxix
mcmlxix's Avatar
I would be interested to see the cold air intake. I will need something for mine. I was thinking a 90* silicone elbow and some 4" (exhaust) pipe to one corner or the other.
Rich
Old 04-12-2012, 03:43 PM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
Exaggerate!
-Chris
Old 04-12-2012, 07:41 PM   #23
mooseknuckles
.....where are the pics man?
Old 04-12-2012, 08:07 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the EFI install Kurt. You always do first rate work on your truck. I like the intake painted too. You'll be back on the road in no time. Good luck finding that tranny.
mcbassin is offline   Reply With Quote
Old 04-13-2012, 12:18 AM   #25
mcmlxix
mcmlxix's Avatar
Rich
