Old 04-05-2008, 02:46 PM   #151
Hart_Rod
Hart_Rod's Avatar
Re: For those waiting on Camaro caliper brackets....
Originally Posted by glock35ipsc View Post
Did you have the inner hole of the rotor machined to open it up to fit over the "bump" on the axle, allowing it to fully seat on the axle flange? That looks to be about the distance that the "bump" protruded out from the flange face.
I did Bob. That's what makes this so puzzling.
Hart_Rod is offline   Reply With Quote
Old 04-05-2008, 05:25 PM   #152
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I'm still thinking, Rob. I have been looking over pictures of mine that I have on this computer and I can see that my calipers are bolted directly to the bracket with no shims, and centered over the rotor, so I am puzzled too as to why this is happening......
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-05-2008, 05:46 PM   #153
glock35ipsc
You might send Frizzle Fry a PM. I found this pic on his burb build thread, it doesn't look like he is using shims either.
I can't be too much help right at this moment in comparing notes since I have my rear-end torn apart.
Bob
Old 04-05-2008, 07:47 PM   #154
Hart_Rod
Hart_Rod's Avatar
Bob can you get a measurement from the bracket mounting surface to the back and front of the rotor?
Old 04-05-2008, 08:40 PM   #155
glock35ipsc
That pic I posted is Frizzle Fry's. My rear-end is torn down at the moment. Maybe shoot Mike a PM and see if he can get them for you.
Bob
Old 04-05-2008, 10:09 PM   #156
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Frizzle, do you have a part # for the banjo bolts? I am going to start my conversion next week when I am on vacation. I am trying to order some S/S braided flex lines, too. Waiting on my brackets back from powder coating. the rotors will be here Monday.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 04-05-2008, 11:00 PM   #157
Frizzle Fry
Frizzle Fry's Avatar
I haven't picked up the banjo bolts yet. I just figured I'd ask for 97 camaro rear banjos at NAPA and go from there. Here's what they show online.
On the shims; I did end up putting the washer from glock's kit between the bracket and caliper, and a lock washer under the bolt head (in place of the flat washer). Mine was definitely not as severe as yours Rob. How thick are the square spacers on the brackets? I think glock changed those on the second batch (partially my fault). They needed to go thinner, not thicker. So if you have the thicker square spacers that's part of the problem (mine are from the first batch and are the same thickness as the brackets). Also, have you bolted your wheels on yet? The rotors will probably seat a little more when you do. The last thing I can think of would be if the outer pad was not seated fully outboard in the caliper.
Frizzle Fry is offline   Reply With Quote
Old 04-06-2008, 12:32 AM   #158
Hart_Rod
Hart_Rod's Avatar
I torqued the rotors down with five open headed bolts, so I don't think that is the problem. I looks like the welded on spacers is the difference. What size should those welded on spacer's be? I would rather change those than add the spacer back in between the calper and bracket.
Also, FF, what are those weights that are attached to your calipers for? I bought a set for core's that have them, but my new calipers from NAPA don't. The new ones have a totally different bracket setup that won't even allow you to bolt the weights on. Any ideas? Thanks,
R
Old 04-06-2008, 01:07 AM   #159
Frizzle Fry
I'd remove the spacers and replace them with whatever size spacer puts you in the right spot. They don't have to be welded on. Those weights are resonance dampeners since they are floating calipers. GM uses them a few places I've seen. Including one on my T56 Transaxle.
Old 04-06-2008, 01:20 AM   #160
Alvin
Never Done?
Alvin's Avatar
Thanks for that info, I'd been wondering what those things were too. So without them you may get quite the squeal?
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 04-06-2008, 02:34 AM   #161
Frizzle Fry
Probably more of a chattttttter at certain speed and pedal pressure combinations.
Old 04-06-2008, 05:18 AM   #162
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Frizzle, how hard was it to bend you hard lines to fit in the back of the caliper? I'm going to try this instead of buying new lines.
Old 04-09-2008, 04:35 AM   #163
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
My calipers look different. I didn't get the surround for the brake pad and mounting area. Will it come with the brake pads?
Old 04-09-2008, 04:39 AM   #164
Hart_Rod
Hart_Rod's Avatar
Mine came with the calipers.
Old 04-09-2008, 04:49 AM   #165
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I guess it's because I bought unloaded calipers. I will take them back tomorrow and exchange for loaded calipers. They are only $11 more.
Old 04-09-2008, 05:09 AM   #166
Frizzle Fry
Easy with a bender Without one, not sure. People do it. If you don't have a line bender use a pipe or something to set the radius and avoid kinks.
I'm going to use the Camaro flex lines as advised.
Old 04-09-2008, 05:11 AM   #167
Frizzle Fry
Only $11 more for loaded?!? Doesn't seem right.
Old 04-09-2008, 05:14 AM   #168
Hart_Rod
Hart_Rod's Avatar
I paid $165 apiece for my calipers at Napa (core charge was $82) and another $50 for the pads.
Old 04-09-2008, 05:16 AM   #169
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
So, does the camaro flex line screw on to the T junction, or do you add it to the old hard line on the axle tube. Here's a link for the $11 loaded caliper. http://www.partsamerica.com/ProductL...rchFor=Caliper
Old 04-09-2008, 05:19 AM   #170
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
My neighbor is an assistant manager at Advanced auto. I got a pair of unloaded calipers for $170 total, core included.
Old 04-09-2008, 05:24 AM   #171
Frizzle Fry
Yes, the flex lines are adapted to the existing steel lines (still requires bending) with the adapter provided in Glock's kit. The flex lines are only like 6" long. At least that's the theory, I have yet to install mine.
Old 04-12-2008, 03:21 AM   #172
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The mounting bracket on mine is rubbing the rotor.
Old 04-12-2008, 06:00 AM   #173
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Looks like I'll need to do some shimming.
Old 06-04-2008, 11:18 PM   #174
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Frizzle, and Hart Rod are you guys using the NAPA Camaro parking brake cables part # 94724?
Old 06-04-2008, 11:22 PM   #175
Hart_Rod
Hart_Rod's Avatar
That's correct.
