Old 07-10-2007, 09:03 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Talking For those waiting on Camaro caliper brackets....
****AS OF 4-22-09 - I HAVE MADE 25 MORE SETS AND THEY ARE READY.****
GO TO http://67-72chevytrucks.com/vboard/s...01#post3273001 FOR MORE INFO
I've been putting ya'll off long enough now, but staying busy is a good thing! I got some time today to work on the new design, and things look VERY promising!
Pics are below. Now, these are just test pieces. These are cut from 1/8", as that is what was on the table at the time. The final parts will either be 3/16" or 1/4".
They will consist of two pieces. Also, overlook the washers that I'm using as spacers!!!! I did not have the right length for the two that hold the caliper on, and the ones in between the two brackets will be replaced with a spacer piece that will be welding in place.
I have not finalized a price yet. They will be more than the Impala/Caprice brackets since there is twice the material and a little more labor in them, but they won't be crazy expensive. The final material thickness will also play into the price. Also, my compressor has a hard time keeping up with continuos cutting for the number I will be doing. So the first batch will probably be outsourced to my steel supplier and be laser cut. I will not be upcharging for this, and I will sell them at the same price as if I were cutting them here.
Here are the pics, and I will keep everyone updated. If you have already expressed interest to me, I probably have you on my list. I will do a mass P.M. to all those I have on my list in the very near future.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-10-2007, 11:46 PM   #2
shifty
Questionable
shifty's Avatar
Re: For those waiting on Camaro caliper brackets....
i was starting to wonder why i hadn't received a PM as promised
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-11-2007, 12:11 AM   #3
glock35ipsc
Sorry Shifty, business picked up more than expected and I got waaaaaaaay swamped! But now that the dust has settled, I just about have these ready to go. Today was the biggest hurdle, finished up the CAD work and got these test pieces cut out. Just a few tweaks and they will be ready.
Bob
Old 07-11-2007, 12:23 AM   #4
ChevyDude
That looks really good Bob!!! Great job!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 07-11-2007, 12:27 AM   #5
powell72
powell72's Avatar
Boy, that was quick, those were in cardboard this morning!
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 07-11-2007, 12:32 AM   #6
bighead
Looks like another winner Bob! Put me on your list please.
bighead is offline   Reply With Quote
Old 07-11-2007, 01:46 AM   #7
Frizzle Fry
Frizzle Fry's Avatar
Sweeeeet! Just in time
Frizzle Fry is offline   Reply With Quote
Old 07-11-2007, 01:46 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Why two pieces?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-11-2007, 08:11 AM   #9
lowdowndirtyshame67
What rotors do they use? Are they 5 on 5? Let me know how much...
lowdowndirtyshame67 is offline   Reply With Quote
Old 07-11-2007, 09:24 AM   #10
glock35ipsc
gringo - I started these as a one piece design. After trying them on a couple of different rear end housings, I found that the axle housing flange was machined on the outside where the drum backing plate bolted on, but not on the inside. There was variances on the thickness. They might be 1/4" thick near the corners, but 3/16" in between the bolt holes. Some also had a slight taper at the corners on the inside.
The result was that when the bracket was tightened down (it mounts on the inside of the flange), it would "pull" around the corners, or get sucked into the shallower part in between the bolts. This would result in the caliper not being square to the rotor. The brake pads would only touch on, say, the bottom edge of one side, and the upper edge of the other side.
So I tried several different styles of a two piece design and came up with this. This way, the bracket that the caliper actually attaches to is mounted to a square surface, via the outside bracket being bolted to the machined part of the flange. There is a possibility that a little bit of grinding might be necessary, and I do mean just a little bit, on the inside of the flange if it is thicker than 1/4". On my own truck, one side is right at or less than 1/4" thick around the entire flange, and the other side is about .030" - .040" past 1/4". This was near the corners, so just a quick hit with the grinder took care of that.
Sorry for the long drawn out explanation....... but I hope it explains my reasoning for going two piece instead of one.
Alex - Thanks!!!!
lowdowndirtyshame67 - They use 94-96 Impala/Caprice rotors, and they are 5x5".
bighead - Gotcha down!
Chris - Thanks for the housing! That really helped determine that this was the best route to go.
Bob
Old 07-11-2007, 10:28 AM   #11
Goodguytrucks
Looking good !!! Great Job !! I know you have me on the list ....Thanks
Goodguytrucks is offline   Reply With Quote
Old 07-11-2007, 12:03 PM   #12
Alvin
Never Done?
Alvin's Avatar
Bob, I don't know if I'm the list or not. If I am, thanks! If not, thanks for adding me!
Looks great!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 07-11-2007, 12:04 PM   #13
glock35ipsc
I do have you down Adam.
Bob
Old 07-11-2007, 02:14 PM   #14
SCOTI
SCOTI's Avatar
Progress...... Looks like you've been using the ol' noggin to overcome those PITA hurdles. Thanks for the update.
Do you have an ETA for the first batch that will be lazer cut?
I can't remember if this was asked already..... I know you're using the Impala rotor, but which caliper: Impala or LT1 f-body? (They might even be the same P/N for all I know)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-11-2007, 02:19 PM   #15
glock35ipsc
Defiantly the Camaro units. They have the much desired e-brake, where as the Impala/Caprice do not. Still waiting for my supplier to get back to me on the laser cutting, but I would guess that I might have them in hand by the end of next week. Don't hold me to that, but it should be close.
Bob
Old 07-11-2007, 02:31 PM   #16
fastom
That's right, it's Copper!!
fastom's Avatar
How does the E brake work?? Does it operate with a cable?
fastom is offline   Reply With Quote
Old 07-11-2007, 02:40 PM   #17
glock35ipsc
Yes, it basically hooks up the same as the drum brake style. This is not my truck, but it shows the basic setup:
Bob
Old 07-11-2007, 03:29 PM   #18
Rickey
Rickey's Avatar
Will you have the e-brake cables, and the adapter for the brke line available with the brackets.
Rickey
Rickey is offline   Reply With Quote
Old 07-11-2007, 03:41 PM   #19
glock35ipsc
Rickey
I am only supplying the brackets and mounting hardware. The e-brake cable is part of the caliper, those are parts you will need to source out. If the brake line adapter is the same as the Impala/Caprice ones (and I think they are) they will be included with the brackets.
Bob
Old 07-11-2007, 04:07 PM   #20
Truckstr
Truckstr's Avatar
Thumbs up Re: For those waiting on Camaro caliper brackets....
Can I get an Amen!
Alright, looking good.
Can't wait.
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 07-11-2007, 04:10 PM   #21
shifty
Questionable
shifty's Avatar
What make/brand of 5-lug axles have these been installed with on our trucks?
Old 07-11-2007, 04:13 PM   #22
glock35ipsc
Bob
Old 07-11-2007, 04:23 PM   #23
glock35ipsc
shifty - of the few conversions I know of, they have all been done with stock axles, both with the 94-96 Impala/Caprice and the 93-97 Camaro calipers.
Bob
Old 07-11-2007, 04:28 PM   #24
shifty
Questionable
shifty's Avatar
Ah, I see. I have 6-lug axles. I'm going to need to convert, I suppose.
Always a catch!
Old 07-11-2007, 05:10 PM   #25
Mixup
Bob,Will you supply a list of parts needed to install them?
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
