Old 12-09-2013, 09:59 PM   #151
bj383ss
bj383ss's Avatar
Re: SANFORD build thread
Thanks for the info. I was guessing a die grinder but didn't know what kind of disc. Will be buying some and trying them out. Been using a wire cup brush on an angle grinder along with a 60 grit abrasive disc. Very tiresome. I just got a new air compressor that will actually run tools. 90* Die grinder is on the list.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-11-2013, 07:23 PM   #152
flips72
flips72's Avatar
at the rate your going I bet I will see this at the spring rod run in pigeon forge, great work.
flips72 is offline   Reply With Quote
Old 12-12-2013, 09:06 AM   #153
jhrusk
Thanks Flip, probably 2015 I cant seem to keep other stuff from creeping in.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 12-12-2013, 09:28 AM   #154
1963c-10
1963c-10's Avatar
Progress is coming along nice and the truck is looking great. Looking forward to more updates.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-13-2013, 12:22 AM   #155
Dinos63
chevy only
Dinos63's Avatar
love your work!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-13-2013, 09:53 AM   #156
chevyrestoguy
chevyrestoguy's Avatar
I REALLY like this truck! I'm blown away at your attention to detail, and how you look at every aspect of the truck and make it better than before. Things like the upper A-arm mod, the brake line routing, and the door gaps are the stuff that I really enjoy. Also, you're a man after my own heart.....I love the big/little wheel and tire combination.
You are going to have one awesome truck when it's done.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-14-2013, 08:01 PM   #157
jhrusk
Thanks so much guys,I watch everybody's thread and love seeing all the great ideas people have.
Old 12-16-2013, 09:24 AM   #158
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Getting the gaps done now is how I did it. However once you install seals all bets off and you still get to move it all around. I am now removing the softseal for new door seal on the drivers side. I am going with steel seal and done with it. Truck is done and I hate the way the door sits out due to the seal.
GMR-PERFORMANCE is offline   Reply With Quote
Old 12-17-2013, 09:16 AM   #159
jhrusk
you are right about the seals but i have a spare set that I tape in place when I get to the final point to keep everything in place. I bet after it is painted and the seals are glued in place I will definitely still have to do some tweaking.
Old 01-09-2014, 05:36 PM   #160
flips72
flips72's Avatar
hope this helps on the door to fenders
Old 01-09-2014, 08:39 PM   #161
jhrusk
Thanks a ton Flip that does help, they look great. However I am a little unsure if mine will turn out as well as yours but I needed a reference. Thanks. Let me know if I can return the favour.
Old 03-10-2014, 05:48 AM   #162
64chevtruck
Hi there, Nice build and great skills. I was wondering what you did to fix your pinion angle?>? And the pic of your LCAs aired out shows the bag rubbing the side of the cup, did you ever had any problems with that down the road>?
Thanks for sharing and keep up the great work
Have a good week.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 03-10-2014, 02:57 PM   #163
jhrusk
Thanks, as far as the pinion angle goes I had to wait until I had the engine and trans in it's final location, at that point I set the rearend at the same angle only the rear was a positive angle and the trans was a negative angle. It keeps both u-joints in the same plain as far as angles go. Although it does'nt look it there is probably a 1/2 inch clearance around the bag. Thanks for looking.
Old 03-10-2014, 03:03 PM   #164
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Dude! Sweet build!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-07-2014, 11:54 AM   #165
cortcomp
cortcomp's Avatar
Man this is awesome work, with your attention to detail, when you get to paint time you will have no trouble turning out an awesome finish.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 06-27-2014, 10:06 AM   #166
jhrusk
here is a long over due post. I am still working on paint a body work as time allows, I am currently fitting a repop door on the passenger side and also bought another hood and have to replace the front panel. I have been going back and forth on just taking it somewhere to finish the paint and body work but I don't know. I have never had anyone paint something like this for me. anyway Thanks for looking.
Old 06-27-2014, 10:09 AM   #167
jhrusk
few more pics.
Old 06-27-2014, 10:10 AM   #168
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice!
Old 08-26-2014, 02:45 PM   #169
jhrusk
been slacking on updates but her are a few of hood repair and general body work
[attach]1.Name:  DSC03246.jpg
294170[/attach]
Old 08-26-2014, 02:47 PM   #170
jhrusk
few more
[attach]1Name:  DSC03251.jpg
Size:  34.3 KB294175[/attach]
Old 08-26-2014, 02:53 PM   #171
jhrusk
and a few more.[
[attacattach]1294178[/attach]h]1294180[/attach]
Old 08-27-2014, 08:42 AM   #172
aggie91
I'm just glad to be here!
aggie91's Avatar
Wow that was some extensive hood repair. The repairs look nice. Where did you get your repair panels from?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-27-2014, 01:08 PM   #173
jhrusk
thanks aggie I got the front panel from fixmyrust.com it fit really well for an aftermarket piece.I also removed both inner structure braces and had them blasted then sprayed them with dp90 before re-installing them.Hopefully to never have rust issues again. I also ended up not using the repop door as it would take a lot of work to make it fit.I repaired my original door and went from there.
Old 08-29-2014, 07:45 AM   #174
jhrusk
A few more of body work,I have broken the body back down to finish up yhe cab and then I hope to be spraying color within the next month.Took a lot of time for panel fitment and gapping. it is a long way from perfect but it is a little better than the way it came]
[attach.Name:  DSC03260.jpg
Size:  37.2 KB1295302[/attach]
Old 08-29-2014, 08:16 AM   #175
1963c-10
1963c-10's Avatar
Truck is looking great. Nice job on the hood repair....the hoods can be real fun to fix metal on. Keep up the great pics and updates.
