Old 01-04-2021, 10:15 PM   #176
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
today we modified the sender and installed an in-tank pump. we also cleaned/painted Orson's accessories.
skymangs is offline   Reply With Quote
Old 01-05-2021, 09:42 PM   #177
skymangs
skymangs's Avatar
I know it may not look like much, but cleaning/painting those accessories is very time consuming! we also put on the intake and mapped out the fuel system. it appears that when Alex took this motor apart he must have tossed the bolts/re-usable gaskets, cause we sure as hell can't find 'em!
Old 01-05-2021, 09:47 PM   #178
gigamanx
Radiator looks very familiar. Are you going to cut the lower outlet to angle it towards the fender? I think I had to do that with mine so it wouldn't hit the belt
Never mind, just realized it's an ls lol maybe it doesn't have the same problem as a sbc 350
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 01-05-2021, 09:51 PM   #179
skymangs
skymangs's Avatar
nope, I use a Canton straight thermostat housing. makes it a nice straight shot!
Old 01-06-2021, 09:01 AM   #180
8man
Please show pictures of the radiator hook up when done. Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-06-2021, 10:29 AM   #181
skymangs
skymangs's Avatar
will do!
Old 01-06-2021, 10:18 PM   #182
skymangs
skymangs's Avatar
spent most of the day looking for bolts, but we managed to get the accessories on, and start building the exhaust.
Old 01-07-2021, 12:15 PM   #183
skymangs
skymangs's Avatar
I realize it 's not a Chevy, but here's another project we're working on https://67-72chevytrucks.com/vboard/...d.php?t=816579
Old 01-07-2021, 09:57 PM   #184
skymangs
skymangs's Avatar
my son, Michael, threw a tantrum and quit yesterday! it's just as well, he was a terrible employee! I've wanted to fire him for the last year, but haven't because he's my son! he was actually costing me money! so for the next few days I'll be moving stuff off the x's property. today we got the dipstick in, the intake manifold torqued, and some other odds and ends that needed to be done. only spent about 2 hours on it.
Old 01-09-2021, 03:01 AM   #185
NorCalGal
NorCalGal's Avatar
Sorry to hear that, it’s a hard thing working with family.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 01-09-2021, 03:07 AM   #186
joedoh
joedoh's Avatar
well that sucks plenty but the truck is looking good
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-09-2021, 09:53 AM   #187
skymangs
skymangs's Avatar
yeah, he acts like I should be sucking without him, but I'm just not!
Old 01-12-2021, 11:10 AM   #188
skymangs
skymangs's Avatar
we got the coil packs cleaned and mounted yesterday. today we'll work on wiring it and the fuel system.
Old 01-15-2021, 09:50 PM   #189
skymangs
skymangs's Avatar
so we discovered a problem yesterday, the hole that we had drilled and tapped was inaccessible when the pump was mounted ! so today we corrected that. a 1/8 pipe plug was put in the hole and a new hole was drilled and tapped on top.
Old 01-15-2021, 10:02 PM   #190
skymangs
skymangs's Avatar
we also got the exhaust built back to the muffler. that's as far as we go until the bed's back on (for aesthetics) almost ready for initial start up! yesterday we discovered that the harness I had ordered was for a car manifold! luckily, I found one on LS1TECH!
Old 01-17-2021, 05:56 PM   #191
joedoh
joedoh's Avatar
looking really nice chris
i think we might need an update on who is left when you say "we". do you have a mouse in your pocket?
Old 01-17-2021, 06:05 PM   #192
skymangs
skymangs's Avatar
I'm sorry, my son threw a tantrum and quit (that's OK he was a ****ty employee anyway) I have 2 in my employ currently, Wyatt (he's my go to guy) and JP(he is still very much learning)
Old 01-20-2021, 11:52 PM   #193
skymangs
skymangs's Avatar
here's what we've been doing the last few days. we made the upper radiator mounts and made all the battery cables, no crimps, only solder! it seems I ordered a harness for a car intake and injectors. so now we are waiting on the car intake to arrive for initial start up.
Old 01-22-2021, 10:57 AM   #194
skymangs
skymangs's Avatar
we discovered that Alex had placed the motor several inches to far forward, at first I tried to compensate, but it became obvious after we got the accessories on, so we spent yesterday prepping the cab and driveline to move back. bummer, I know, but it's the only way to do it right!
Old 01-22-2021, 10:59 AM   #195
skymangs
skymangs's Avatar
more pictures of the process
Old 01-22-2021, 10:05 PM   #196
skymangs
skymangs's Avatar
we spent the whole day preparing to move the driveline. monday we move it! we also discovered that Michael did a piss poor job of welding the floors, so we'll be redoing that too. (he no longer works for me)
Old 01-25-2021, 09:39 PM   #197
skymangs
skymangs's Avatar
here's what we got done today, old motor mount pedestals were cut out, and the new ones will go in tomorrow
Old 01-26-2021, 10:24 PM   #198
skymangs
skymangs's Avatar
we got the engine repositioned today, it's a little far to the right. we need to cut the steering linkage tomorrow and redo the steering geometry. on the trans dipstick, we had to cut and reweld the mounting bracket to move it from behind the head to next to it.
Old 01-27-2021, 10:50 PM   #199
jed971959
looking good
good to see you back at it
On your exhaust I would of put the left pipe behind the trans output shaft about 6" so if the trans ever needs to be removed it makes it a lot easier
jim
jed971959 is online now   Reply With Quote
Old 01-28-2021, 12:21 AM   #200
skymangs
skymangs's Avatar
thanks
