10-27-2022, 08:05 AM | #1 |
70' Blazer 4WD (Wire ID)
I have this wire lead that i don't know where it goes. i don't see it on the wiring diagram. It looks pink to me. Maybe for an accessory?
It may not be from this truck. Any help appreciated. thanks. Last edited by oeespo; 10-27-2022 at 08:15 AM. Reason: Adding more info to subject |
10-27-2022, 10:49 AM | #2 |
Msgt USAF Ret
Re: 70' Blazer 4WD (Wire ID)
Hello and welcome to the board.
That wire could be for an accessory, I don't recognize the connector as anything stock.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-27-2022, 11:46 AM | #3 |
10-27-2022, 07:56 PM | #4 |
Msgt USAF Ret
Yes the transmission controlled spark wiring harness, I forgot about the 70 and 71s. Also the carb idle solenoid has a red wire going to it to hold the idle up if the AC is on.
10-31-2022, 06:20 PM | #5 |
Wondering if that wire number 141 in the diagram is the brown wire in my harness? otherwise, not sure what it is.
11-01-2022, 11:54 AM | #6 |
It might be a TH400 transmission kickdown wire. That grommet on the wire would pop into a hole in the firewall.
https://67-72chevytrucks.com/vboard/...d.php?t=811030 |
