Old 09-14-2009, 05:22 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
I need a passenger side battery box picture..please.
Can someone post a picture of the passenger side battery box. I need to see the area where the inner fender well connects to the batter box. Left and right side pictures of the battery box would be great.
WHY, you ask.
My inner fender wells are not installed yet. I'm trying to see if there is enough room to rum my AC lines between the two.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-15-2009, 05:43 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Re: I need a passenger side battery box picture..please.
What no replies from this chatty bunch. Oh oopps, sorry I forgot to say "PLEASE".
Old 09-15-2009, 08:05 PM   #3
JimKshortstep4x4
I don't have a very good picture but here is what I have. It is an AC battery box and the stock lines fasten to the extra bracket that is attached to the tray. This bracket aligns the two AC lines with the large holes that go through the radiator support.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-15-2009, 11:18 PM   #4
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
You do know that the bottom of the battery box bolts to the inner fender.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-16-2009, 03:44 PM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
Jim
Thanks for the replies, but I think I sould explain a bit more. I would like pictures of the battery box and inner fender installed, because we are running the AC and Heater hoses from the Vintage Air unit to the engine. We are tucking these hoses between the fender and the inner fender to conceal them. The hoses will emerge at about were the fender connects to the rad support next to the battery box. So I need to see how much room there is (if there is any) for the hoses to pass through the under side of the battery box near the inner fender. Or if I need to cut out holes in the lower triangular battery box support to run the hoses through.
I think this explains it, sorry for the confusion.
Old 09-16-2009, 08:07 PM   #6
landsurvey1
landsurvey1's Avatar
Here are some photos that might help. The tray without the battery is on the drivers side, but the dimensions are the same for both sides. From the radiator there is about 1 ½ inches. On the fender side there is 4 inches. The bottom of the tray almost touches the inner fender well as seen in the photos. Hope this helps.
landsurvey1 is offline   Reply With Quote
Old 09-17-2009, 08:26 PM   #7
jugernot
Life, Be In It.....
jugernot's Avatar
Thanks for the pictures. Well from the looks of things I will have to modify the underside support of the battery box and run the AC/Heater hosed through it.
