Old 03-10-2018, 04:25 PM   #1
tjc
tjc's Avatar
Royal Purple
I have a new engine and new turbo 400. Is Royal Purple worth $15.00 a quart? At $15 x 12 quarts=$180.
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 03-10-2018, 05:45 PM   #2
truckster
truckster's Avatar
Re: Royal Purple
Royal Purple is definitely a very fine motor oil, but I wouldn't use synthetic oil to break in an engine.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-10-2018, 06:16 PM   #3
rsavage
rsavage's Avatar
Re: Royal Purple
If your engine has a flat tappet cam I suggest that you use Brad Penn break in oil 30w and after break in, Brad Penn Grade 1 10-40 or 20-50. Available through Summit.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-10-2018, 06:58 PM   #4
tjc
tjc's Avatar
Re: Royal Purple
sorry ....the Royal Purple was the trans fluid. for $15. quart
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 03-10-2018, 08:32 PM   #5
68Gold/white
Re: Royal Purple
No, No, NO!
Regular dexron III in trans and Brad Penn in engine for break in...then what ever oil you want to use...NOT RP!
I'm from Iowa! BTW!
68Gold/white is offline   Reply With Quote
Old 03-10-2018, 09:39 PM   #6
Bigdav160
Bigdav160's Avatar
Re: Royal Purple
Any of the new transmission fluids are synthetic base
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-10-2018, 09:50 PM   #7
Alex V.
Alex V.'s Avatar
Re: Royal Purple
There is no need for special oil in the trans. for break-in. Whatever quality of fluid you feel is necessary for the long-term is good from the start.
Brad Penn and Amsoil, among others, make high-zinc break-in oil. After the first 500 mi. (which should mean the rings have mostly seated and the cam is completely broken in) I'd run a 1,000 mi. change of a good high-zinc conventional (probably something rated SM) or use a zinc additive but *not both*.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
