12-08-2021, 11:07 AM | #1 |
Unfused HEI wire?
I noticed that my HEI wire is plugged into the unfused terminal on the fuse block.
Should I install an inline fuse, if so what size. Thanks K.E.N. |
12-08-2021, 02:24 PM | #2 |
Re: Unfused HEI wire?
That's what I did with mine. It didn't feel right going without a fuse.
Here's the one I used, but I see it's not available now: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 The might be good, too: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
12-08-2021, 09:04 PM | #3 |
Fabricate till you "puke"
I have never done a fuse on that ......Ask you a? , did you see the factory fuse that hei? If you understand, why would you worry about a fuse on the ign system? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-08-2021, 10:04 PM | #4 | |
Does not have voltage with the key off . You are Golden. Less is More
12-09-2021, 01:24 PM | #5 |
Hello,I didn't know that terminal lost power with the key.
Thanks K.E.N. |
12-09-2021, 06:13 PM | #6 |
12-10-2021, 08:48 PM | #7 |
On my '70 there were two of those extra unused unfused terminals. I used one for the HEI and one for the electric choke on my Holley.
12-11-2021, 08:44 PM | #8 |
I put an inline fuse in mine. I remember going bigger than necessary, maybe 10A, so it will never blow under normal use unless it shorts.
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools |
12-14-2021, 12:32 PM | #9 |
Thanks All I will install a 20amp in line.
K.E.N. |
