Old 07-10-2011, 08:10 PM   #1
Woogeroo
Question AC in our trucks with a SBC - which side for the compressor?
Howdy.
I'm just curious... for those of you that have or had added Air Conditioning to your trucks.... looking at the engine from the front of the truck... which side do you have the ac compressor on?
The reason I ask is my alternator is on the left.
Anyway, just curious....
-W
Woogeroo is offline   Reply With Quote
Old 07-10-2011, 08:16 PM   #2
octain
octain's Avatar
Re: AC in our trucks with a SBC - which side for the compressor?
Left side looking at engine.
(which actually is the right side)
72 C-10
04 HD Fatboy
82 Suzuki GS850 Cafe
78 GS1000 Skunk
octain is offline   Reply With Quote
Old 07-10-2011, 08:42 PM   #3
Clyde65
Clyde65's Avatar
most aftermarket ac folks has it set up on passenger side.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-10-2011, 08:43 PM   #4
Woogeroo
Wink Re: AC in our trucks with a SBC - which side for the compressor?
Clyde65, yeah, I've noticed that on a few installs or the instructions for the various setups.
This is how my truck was when I bought it, always thought it was a little funky.
-W
Old 07-10-2011, 10:24 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
When I added A/C I purchased a set of Alan Grove brackets and moved the alternator to the driver side allowing the compressor to mount on the passenger side. Mounting it on the driver side is going to require some inconveniently long hoses.
Old 07-11-2011, 01:50 AM   #6
Captainfab
60-66 Nut
The original location for the A/C in the '72 and older trucks is on the passenger side with the alternator on the drivers side. Of course this is with the short water pump. In '73 when GM went to the long water pump in the trucks, the alternator went to the passenger side and the A/C on the drivers side
Old 07-11-2011, 10:03 AM   #7
LT1 Burb
LT1 Burb's Avatar
Mine is on the driver side.
LT1 Burb is offline   Reply With Quote
Old 07-11-2011, 10:09 AM   #8
Clyde65
Clyde65's Avatar
maybe a serp belt system is in your future?
Clyde65
Rebuild of Clyde
support our troops!
Old 07-11-2011, 11:28 AM   #9
66 lwb cs
66 lwb cs's Avatar
Mine is on passenger and it is a 60's era aftermarket unit installed in 1966
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 07-11-2011, 02:51 PM   #10
awbrown
looks like a newer pump on that 66 setup...
awbrown is offline   Reply With Quote
Old 07-11-2011, 04:32 PM   #11
kieth
kieth's Avatar
I have a 91 burb serpentine belt system and it is on the passenger side, I thought when I measured my water pump it was a long shaft but maybe I misunderstood how to measure it. Kieth
R4 compressor in place now pass side, will soon be a sanborne......
http://kieth.smugmug.com/Trucks/66-G...805843_BqZMQNP
kieth is offline   Reply With Quote
Old 07-11-2011, 08:25 PM   #12
66 lwb cs
66 lwb cs's Avatar
New pump and condenser the old one's went bad so the new ones run R134
Old 05-04-2023, 08:30 PM   #13
karlbenz
My serpentine setup came out of a 96. Compressor on drivers side
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10
1965 Chevy C50
karlbenz is offline   Reply With Quote
Old 05-04-2023, 08:59 PM   #14
Arne
Arne's Avatar
My '64 has an early 80s SBC with passenger-side alternator, and a custom new wiring harness for that application. So the A/C compressor will be on the driver's side.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 05-05-2023, 12:04 PM   #15
SCOTI
SCOTI's Avatar
Woooowee..... Dusted this one off.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-09-2023, 03:59 PM   #16
forestb
forestb's Avatar
x2
forestb is offline   Reply With Quote
Old 05-09-2023, 07:38 PM   #17
Arne
Arne's Avatar
Originally Posted by forestb View Post
x2
There are some fixes for that available now. I'll post pics of mine when I start installing it later this week.
- Arne
覧覧覧覧覧覧
Old 05-09-2023, 08:10 PM   #18
forestb
forestb's Avatar
The first photo is of my old engine and the second is of my new engine. I had to get different brackets because my new engine has Vortech heads and a vortech intake manifold. Both are from Allen Grove.
Old 05-19-2023, 08:50 PM   #19
Arne
Arne's Avatar
Here are a couple of adapter pipes I'm using to clean up and shorten the hose runs with my driver's side compressor. I got these from Auto A/C Solutions, but both are available from Old Air as well.
This first one allows the large suction hose to run along the firewall, behind the carb. Still a medium-long hose, but much nicer routing than over the top.
This extension pipe for the condenser inlet crosses over to the driver's side. It allows the hose from the discharge of the compressor to drop down and connect through the left side of the radiator support. This is a much shorter hose than having to run over the top and into the condenser on the right side.
- Arne
覧覧覧覧覧覧
Old 05-22-2023, 02:00 PM   #20
Arne
Arne's Avatar
And here is the completed install. The extra pipe adapters allowed me to simplify and tidy the hose routing significantly. It turned out nicer than most left-side compressor installs that I've seen.
- Arne
覧覧覧覧覧覧
Old 05-25-2023, 05:56 AM   #21
Android04
Android04's Avatar
Thank you for making me laugh this morning.
Android04 is offline   Reply With Quote
Old 05-25-2023, 08:42 PM   #22
forestb
forestb's Avatar
Grrrrrr. Why are we relying too an old thread.
Old 05-25-2023, 09:25 PM   #23
karlbenz
Sorry bout that. Did a search for something and this came up. didn't notice the date
1964 GMC K10
1965 Chevy C50
Old 05-25-2023, 10:49 PM   #24
cwcarpenter98
cwcarpenter98's Avatar
Not a problem to reply to an old thread if the reply has related information and provides meaningful input to the overall message board.
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 05-26-2023, 08:43 AM   #25
SCOTI
SCOTI's Avatar
x2. I like that people are utilizing the search function & finding relative information. It shows the value in these forums.
That being said, I'm amazed sometimes @ the time gap on some. Twelve years is a pretty decent stretch.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
