Old 07-06-2004, 03:05 AM   #1
mneuen
Question 67 GMC small block 350... want to convert to auto trans
I've got a long bed 67 GMC with a small block 350 in it. I want to change to an automatic transmission without changing the crossmember... Is that possible or what are the alternatives. Any help will be MUCH appreciated! Thanks!
mneuen is offline   Reply With Quote
Old 07-06-2004, 03:30 AM   #2
krue
Designated A-hole!
krue's Avatar
I am not sure if you can put an auto tranny in without the crossmember, the tranny is gonna need the support. If it can be done, someone on here knows how to do it.
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-06-2004, 07:03 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You're going to have to pull the stock standard trans crossmember and use an automatic trans crossmember.
If you're pretty mean with a grinder and sawzall, that standard crossmember takes about 10 minutes to remove. I just pulled mine awhile back when I did this swap.
Old 07-06-2004, 09:21 AM   #4
mneuen
Thanks guys! OK how about this... my friend says a powerglide will fit onto the existing crossmember. What do you think about that?
OK OK What would you use if you were putting an automatic trans on there?
Old 07-06-2004, 09:47 AM   #5
Willy Prost
Original standard shift trucks have a crossmsmber of sorts that bolts to the bellhousing. Use a auto transmission crossmember. Either get a used one from one of the board members or buy a new one from Early Classic Enterprises.
http://www.earlyclassic.com/index.html
Willy Prost is offline   Reply With Quote
Old 07-06-2004, 01:44 PM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Powerglide will need the standard auto tranny crossmember...at mine does! I don't see any other way to mount it.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-06-2004, 04:09 PM   #7
busterwivell
You SURE you want a Powerglide? Personally, I wouldn't. I went from a truck 4 speed to a 700R4 and couldn't be happier. Took a custom crossmember, but it was worth it.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 07-06-2004, 09:33 PM   #8
Quagmire
A splendid one to behold
Quagmire's Avatar
if you get up underneath your truck and take a look versus one with an auto, you will see why everyone is telling you 'no, it won't work'.
i'll tell you the same thing. the standard trannys are shorter than any auto for one. the crossmembers for the standard bolts up at the bellhousing (towards the front of the transmission) while the autos will bolt up towards the rear of the tranny. also, the crosssmembers aren't the same, you will need one for an auto or buy/build a universal one
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 07-07-2004, 12:16 AM   #9
mneuen
Thank you to everyone! I have been up underneath that thing for going on three days (oil leaks... that seems silly... the oil doesn't leak; it flows quite freely out of every possible place) and majority says to go with the 700R4 or the TH350... so again, thanks for all the info. That's good stuff! I'll keep this thread posted on the happenings.
