Got Light Emitting Diode?
i need a little help
quick question. i have asked alot of questions about converting my 68 to front disk, well i think my drum/drum master just went out and as i understand it, if i put my disk/drum master and booster on with my drum/drum prop. valve it will work exactly the same on my drum/drum set up, just hold more fluid. am i right?
thanks for the help ben
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
I'm not sure if I understandd what your saying here, but if you go with disks you'll have o get a disk mater cylinder and you can use your current booster, you will also have to change the equilizer valve as well for disk brakes. I think that is what your asking??
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
Since the calipers use more fluid, (they are larger) than the drum wheel cylinders in front, I would suspect that you will have uneven breaking. The disc brake master cylinder will push more fluid to the front than the drum master cylinder.
Also, I am not sure what would happen if you use the 68 distribution valve with the disc master cylinder. If it were me, I would keep disc components with disc components. Jim |
i want to do the whole swap but i need to get to work tomorrow. to clarify i am seeing if a disk/drum master will work with a drum/drum prop. valve and drum/drum brakes for just a while
well it seems to work. a quick test drive and it stops fine. i couldnt get the booster on though. the holes didnt line up. just a project for another day
