SOON TO BE A STEP SIDE
carrier bearing question
can anyone identify this type of carrier bearing?
how do i remove it? i have this other type on my long step (pic4) there is a tremendous amount of play in the bearing itself i need to change it
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY! 4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON |
it's held in the crossmember by 2bolts on top unbolt it and unbolt the rear ujoint and slip the driveshaft out of the truck press out the center ujoint unbolt yoke slide carrier bearing off . make sure to mark everything so you put it together in-phase
Those are the 2 different kinds that were available. I use the ones that inland empire driveline service sells on mine. They are made out of aluminum and way way stronger. They are also about $120, but I am not willing to pay $40 for a regular one every 6 months.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Mike
neonlarry,did You have any problems getting it to fit?They where at Carlisle,but the guy at the stand didn't know if it was the right size.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
The LuvShack Garage
I SWITCHED MINE OUT 2 A SINGLE DRIVE SHAFT, I'M NO HELP AM I :p
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
smokekiki, yes I had to machine the top portion so it would fit up inside the bracket. But I have been told that they fixed this, I'll let you know in a couple of weeks. Got a new one for the Burb, it is going in when I get a chance to replace the tranny.
