09-21-2004, 04:19 PM | #1 |
C10 Collector
Lay Cross member with stock control arms????
Alright guys, I read every post here, and followed them for a while now, and i have a question.
Is it possible to lay the front crossmember(well actually the lower a-arms cause they're lower) with stock upper and lower control arms. I've seen most people use different control arms. I have art's kit, which is plate on top, cup on bottom. I also have mcgaughy's 2 inch dropped spindles and baer brakes. I'm about 1.25 inches from laying crossmember, but can i go lower with stock arms, at least the lower ones? By the way I'm riding on 20's, about 27-28 inches tall. Thanks guys! |
09-21-2004, 06:24 PM | #2 |
www.73-87chevytrucks.com
Not sure what year you are talking about, but all should be applicable.
This was a truck I had my bag setup in with no spindles and about 28" tall tires, having the front sheetmetal and engine would have it dragging the ground.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-21-2004, 07:28 PM | #3 |
Trucker.
I was rolling a 235/60/15 with 3" DJM spindles and an ART cool ride kit and the bag still had about 30 psi when the LCA's were laid out.
09-21-2004, 07:43 PM | #4 |
C10 Collector
yeah, my truck is a 72. Did you do anything special to get yours so low? I only need like another inch or so. Are art's cups bigger or something?
09-22-2004, 03:14 AM | #5 |
Project92 SWB stepside
If you are using the plate which mounts to the member you will not sit as low. The cup style actually sits in the member a inch or so.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
09-22-2004, 03:59 AM | #6 |
C10 Collector
cups
So, if I pull the plate out, and put cups in the top it should sit on the ground correct?
09-22-2004, 04:45 AM | #7 | |
09-22-2004, 04:49 AM | #8 | |
Happy to be here
09-22-2004, 06:55 AM | #9 |
I am laying crossmember
I dont have any pictures of it all the way down, but here is a pic from when I first bagged it before I redid the brackets. its a few inches above ride hieght and I am running 2.5" dropped spindles on 285/30/20's |
09-22-2004, 06:58 AM | #10 | |
I see Impala SS wheels, let me know if you ever want to sell those. I could use a spare set for my car. |
09-22-2004, 06:16 PM | #11 | |
09-22-2004, 06:44 PM | #12 |
C10 Collector
hmm
Maybe I'm not as low because I only have 2 inch dropped spindles. I have 245/40/R20 tires on the front. I have Art's kit on the front, and the crossmember is an inch up. It just seemed like everyone else was lower than me, and I was seeing if anyone else was layin lower with 2 inch spindles and stock control arms.
Any recomendations as to what I can do. Baer's brake system came with the 2 inch spindles because they had to modify them or something. If I can go from a plate to a cup in the top and get another inch that would be cool. But I'm not sure if a cup will give you an extra inch. |
09-22-2004, 11:38 PM | #13 | |
Not sure why you aren't since the one I posted has stock spindles on it.
I do know that my lower cup is just tall enough to keep the bag from touching the LCA. IF you did go with a cup on top, you can get it lower, but you will have to investigate how much lower. Baer had to modify the spindle for the new rotor shaft from what I remember. The stock one won't go on there anymore since it has a new shaft. I can notch your crossmember and give you up to 1.5" of drop. Quote:
09-23-2004, 12:46 AM | #14 |
C10 Collector
yeah. I want to get the crossmember down, then I'll notch the crossmember your way, and bridge the rear for the final drop.
09-23-2004, 06:04 AM | #15 | |
yep, they are chrome. Thats my second set of chrome wheels, the first set started to peel and the previous owner got some nasty curb rash on them too. |
09-25-2004, 04:03 AM | #16 |
C10 Collector
Alright Guys,
I looked over my truck again today. I'm like 1 inch from the control arms hitting the ground, since they are lower than the crossmember. I can't figure out why my truck is sitting an inch higher than everyone else on here. I have Air RIde Technologies kit with an upper plate bolted to the crossmember flange, and the cup in the control-arm. I'm going to try to put it on the lift tomorrow, and take a better look at the cups, but they're sitting in there pretty far. I looked, and nothing is binding up, so I'm dumbfounded. Any Ideas??? |
09-25-2004, 04:18 AM | #17 |
C10 Collector
I was just thinking, I wonder if it is my shocks holding the truck up??? Who knows, but I'm going to check it tomorrow.
09-25-2004, 10:28 AM | #18 |
ART kits are designed to not let the crossmember hit the ground. They don't want to be responsible for people railing then comming back to them for a new crossmember or control arms. Chances are it the shocks or the bag brakets.
09-25-2004, 01:15 PM | #19 |
I dropped my crossmember 1.5" usin Capt's method, running 2" dropped spindles, and the bags with no lower cups and mine lays frame from front to rear. Had to rebuild tranny and swing bearing crossmembers and notch the hell out of the back to get it this low though. On the front on these trucks the crossmember is shallow and smooth so you can run the bag sittin in the crossmember without a cup for couple extra inches.
09-25-2004, 05:22 PM | #20 |
yo ghetocrewzer, did you drop the crossmember yourself? how labor intensive was it? I am thinking about doing my friends 71.
09-25-2004, 06:02 PM | #21 | |
Bags alone, or did you have to block it as well? Thanks |
09-26-2004, 06:08 PM | #22 |
www.loweredd.com
I had to use a 10" notch for my old 305/50/20's. I'm about 2" from the top of it now.
09-27-2004, 12:46 AM | #23 |
yeah i did all the work myself and built a 9" notch. Sublvr the crossmember just takes about a good 4-5 hours of fab time and you have to be sure and get it aligned right before welding. My ride is a Suburban so i just took the whole wood floor out and am buildin new rear floor for it out of tubing and thin steel
09-28-2004, 09:23 PM | #24 | |
Seņor Member
09-28-2004, 10:00 PM | #25 | |
Happy to be here
