Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 10-03-2004, 09:52 AM   #1
jd4300fel
jd4300fel's Avatar
1990 chevy won't start after running
hello,
I have a 1990 chevy, with TBI that won't start up after running 10 minutes or longer. there is no fuel comming out of the injectors while the engine is turning over. a quck blast of starting fluid and she runs fine.
Any body have any idea's I suspect a sensor some where.
Mike
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 10-03-2004, 02:42 PM   #2
Motor City
did you check for fault codes?
is your fuel filter good? did you check the fuel pump for proper operation and correct pressure?
Motor City is offline   Reply With Quote
Old 10-05-2004, 03:35 AM   #3
73stepside
73stepside's Avatar
change your ingition module...the injector signal is sent thru it...could also be your fuel pump or the fuel pump relay
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 10-06-2004, 11:58 AM   #4
jd4300fel
jd4300fel's Avatar
Thanks,
In the future I will try to post these in the correct group.
thanks again.
Mike K
Friend of Bill W
