Old 10-11-2004, 09:08 PM   #1
ScottH
ScottH's Avatar
Can a late 70's tilt column be used in a 65?
Considering picking up a 65 and have a late 70's van tilt column laying around. Can anyone tell me if this column would fit in a 65?
Thanks.
ScottH is offline   Reply With Quote
Old 10-12-2004, 02:22 AM   #2
BrianJordan
Iron Thunder
BrianJordan's Avatar
yes it will,but u will need to bild a new dash mount. i put 84 cady column in my 64.
BrianJordan is offline   Reply With Quote
Old 10-24-2004, 11:38 AM   #3
ChevyStepside
Yes you can.. I have a 76 van column in my 65.. Just mount it where you want it and put the parking brake/steering column mount in and mark the two holes and weld some nuts onto the steering column so you can just use the one bracket.. You might have to cut the bolts to fit.. Also you will have to use a lower steering column to the box that can be joined with a u joint from Flaming River or someplace.. Splined to DD joint.. I have some picture at http://community.webshots.com/album/73633195rsVEee
ChevyStepside is offline   Reply With Quote
Old 10-24-2004, 03:46 PM   #4
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
ok
ok then what year tilt column fits with no problem ,if there is one , don't want to any thing extra .
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 10-24-2004, 06:21 PM   #5
ChevyStepside
for a sure fit with nothing to do you will probably have to get one from Flaming River or Ididit... they start at $300 for unpainted steel and no shifter on the column... Then you still have to do the lower steering column but they should be able to sell you all you need... I got the tilt column from pick and pull on Half Price Day for $28...
