10-19-2004, 03:08 PM | #1 |
What size wheel fit best?
I recently dropped my 69' chevy c-10 and the 15x8 wheels I have on there now rub the fenders when i go over bumps and with body roll on turns. Have any of you experienced this problem and what is a good fit for new wheels...I am thinking of going to a 16x8 or a 17x8 centerline snipers. The drop I did was a 2.5 in spindle drop from CPP and a 1 in spring drop from ECE. The rear is a 5 incher from ECE. Please help!
The Centerline Snipers have a 5in backspace and a 12mm offset. By the way, does anybody know what the bolt circle specs for a 6 lug? Is it 4.5 or 5.5 inches? |
10-20-2004, 07:17 PM | #2 |
67-72 parts collector,…
5 inch backspace on the FRONT is perfect for an 8 inch rim. 6- lug b.c. is 5.5 inches.
10-20-2004, 09:20 PM | #3 |
Watch out for your cornhole !
I run 8 inch fronts with 4.25 backspace. They fit great with no clearance issues.
Mine is lowered 4.5 inches in the front too.
