10-22-2004, 10:11 PM | #1 |
The LuvShack Garage
Help W/ Rear Seat
WHY DO THREE OUTA FOUR BRACKETS HAVE SEAT BELT ANCHORS
* BIG CIRCLES ACROSS THE BOTTOM OF THE BENCH SEAT I KNOW THERE USED TO BE A BELT ANCHORED 2 EA. END * SMALL CIRCLE ON THE LEFT SIDE OF PICTURE NUMBER 1 I WANT ANOTHER FOOT TO MATCH THE OTHER THREE , I'M NOT GOING TO RE-USE THE END BOLTS, LOOKING FOR A 4TH FOOT SO I CAN JUST CONNECT ALL OF MY BELTS THAT WAY. PIC'S ATTACHED FOR REFERENCE TO MY QUESTION
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-22-2004, 10:47 PM | #2 |
Thats kinda messed up, I don't know how the rear seat belts work, on mine its just a big belt going from one end to the other, like 2 people could fit in it.
10-22-2004, 11:02 PM | #3 |
The LuvShack Garage
Yea Gee, It Had One Attached To Each End And Then 3 Attached To
The Bolt Holes Seen In The Pictures, Still Has 1 Seat Belt In It, The Others Were Cut At The Edge Of The Seat Cover Where It Overlaps.
10-22-2004, 11:04 PM | #4 |
it will probily be hard to find just one, id just drill it out and tack weld a bolt on the back side, you`ll be cleaning, and painting them anyway..
jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
10-23-2004, 09:30 AM | #5 |
The LuvShack Garage
I Thought Maybe I Would Get Lucky And Find A Trashed Rear Bench
I Could Rob The Parts Off Of, My Arm Rests Are Bad Also, Ttt
10-23-2004, 11:33 AM | #6 |
i got some nice arm rests but they are blue....
jamie
10-23-2004, 12:35 PM | #7 |
Are rear benches that hard to find? I have passed up a few in junkyards, I just headed straight for the hold down clamps and grabbed them.
10-23-2004, 02:28 PM | #8 | |
The LuvShack Garage
BEEN TO 15 JUNKYARDS IN LAST 3 MONTHS, HAVE YET TO SEE THE REMAINS
OF ANY BLAZERS, NEVER SEEN ONE IN A YARD BEFORE, HARD TO BELEIVE. Quote:
10-23-2004, 04:00 PM | #9 |
SKINNY TIRES RULE!
LUV - My '72 has only 2 of the brackets on the rear of the seat. GM didn't put the two center brackets on all the seats. The center seat belts bolt directly to the floor. I know this is stock because just about everything on my truck is stock, I have seen it on other trucks, and the rear seat I bought for my '69 from Kilomanjaro doesn't have holes to bolt on the two center brackets.
I would guess that your rear seat has been frankenstien'd at some point in time. The outside bracket may be from a suburban with shoulder belts or something - who knows. If you don't want to go to the trouble of searching for just one bracket, I would remove two and put the remaining two on the outside. Or swap the one with the hole to the inside positon and mount the seatbelt to the bolt hole that goes to the floor.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
10-23-2004, 04:29 PM | #10 |
The LuvShack Garage
Hmmm, Well I Really Did Not Want To Use The End Bolts, Even
Though That Is How Stock Is, I Thought With 4 Matching Type Brackets I Could Just Have 3 Lap Belts And Nothing On Floor.
10-23-2004, 04:39 PM | #11 |
SKINNY TIRES RULE!
I understand. I think the suburbans used the same brackets in the 3rd row.
10-24-2004, 08:25 AM | #12 | |
The LuvShack Garage
10-24-2004, 01:02 PM | #13 |
I am still searching for the front bar hold downs if anyone has a pair.
Thanks, Bret |
10-24-2004, 01:58 PM | #14 |
SKINNY TIRES RULE!
teamharvey, did you contact TONYP to see if he is still making them? I think he was asking around $30 a set. They don't look like the originals, but they function the same. I think he machines them out of solid aluminum.
10-25-2004, 04:43 PM | #15 |
The LuvShack Garage
TTT
10-25-2004, 05:36 PM | #16 |
SKINNY TIRES RULE!
LUV, contact Kilomanjaro. He may have a few extras laying around. I haven't seen much of him on the board in recent months, so hopefully he is still dealing with truck parts.
10-25-2004, 05:53 PM | #17 |
The LuvShack Garage
Pm'd Him And Cheesewagon, Thanks
10-26-2004, 12:50 AM | #18 | |
Does anyone have a pic or deminsions of them ? thanks, Bret |
10-27-2004, 03:17 PM | #19 |
The LuvShack Garage
TTT
10-27-2004, 04:52 PM | #20 | |
AKA Phillip Johnson, AKA BANNED!
10-27-2004, 06:56 PM | #21 |
My 72 only has the outer brackets. My 71 only had the outer brackets. Believe Kilamangero moved to Alaska a while back. He still posts some stuff on e-bay----beleive his name is John.
10-27-2004, 08:36 PM | #22 |
belt
mine has belts bolted to the outer on on each end , both belts bolt to the center bracket in the middle i believe it is original because it has a cover big enough to cover both when bolted together. ??????//?
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE |
10-27-2004, 10:54 PM | #23 |
Suburban middle seat brackets are not the same as blazer ones. They kinda look the same, but blazer ones are short in the front, tall in the back, and suburban ones are tall in the front, short in the back. I have 2 extra sets of the back ones for the suburban seat, but I dont have a blazer, so no blazer seat brackets.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
10-29-2004, 03:51 PM | #24 |
The LuvShack Garage
MINE APPEARS TO ALSO FOLD FORWARD IF THE ARM RESTS WERE OFF
10-29-2004, 04:31 PM | #25 |
Active Member
Blazer rear seat, and Suburban middle seat mounting brackets are a little different, but the Blazer rear and Suburban's 3rd row seat mounting brackets are the same.
They both use 2 or 4 tall mounts for support in the rear of the seat. And 2 short pipe type mounts for support in the front of the seat. |
