04-07-2002, 09:18 PM | #1 |
Shortbox wanna-be.
Rocker Replacement Question. (Weather stip rail?)
I have to replace the passenger side lower rocker panel on my truck. So today I decided to pull out all the interior floor stuff, like seat, mats, and underlay to see what I would find. All looks really well, but the passenger side channel rail that the weather stripping clips onto in toast on the pass. side. Now does that little rail come as part of a complete rocker? Or is it something that I would have to build on there once the new rocker is in place?
Reid ------------------ Sylvan Lake, Alberta, Canada 1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. A/C, P/S, manual brakes. 75,800 Original Miles!! '71 Camaro SS 402/T400 resto '97 Z28 -- Runs 11.5 @ 118mph.
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
04-07-2002, 09:23 PM | #2 |
I can't speak for all rockers....but the weather stripping "lip" was on the rockers that I bought.
Hope this helps.... ------------------ Keep On Truckin' Shane slecroix@bellsouth.net Athens, Alabama |
04-07-2002, 09:24 PM | #3 |
The lip for the weather stripping is part of the new rockers.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-07-2002, 09:26 PM | #4 |
Shortbox wanna-be.
Excellent! I thought it might, but wasn't sure.
Anyone here done their own? I am sure if I was really careful I could pull it off. I am pretty good with the mig welder.
04-07-2002, 09:35 PM | #5 |
now thats a true COON DOG
Yes I have done rockers! there very easy. You need to remove the old rockers. Slip the new ones into place (dose not take much to line the new one up) and weld into place.
------------------ 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE with built 350 4-speed 4.11's and posi
current project 67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!) 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well... 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
04-07-2002, 09:38 PM | #6 |
Shortbox wanna-be.
Is there anyway you could describe a step-by-step process to do this? Like where to start, best tools for the job, pointers, etc?
I would be forever in your debt!!
04-07-2002, 10:00 PM | #7 |
They are held on by spot welds, so what I would do is drill the welds out and replace the rocker then plug weld it back on.
How come you are replacing it, I thought that truck was rust free? ------------------ 1969 Chevrolet Custom Camper 20 350/400 70k original miles They have the Internet on Computers now? --Homer Simpson Gee_Emm's Page Help me get my truck on a soda bottle!!!!! [This message has been edited by Gee_Emm (edited April 07, 2002).] |
04-07-2002, 10:08 PM | #8 |
Shortbox wanna-be.
I got all the carpet and all pulled out and found a couple of small holes in the rocker, where the weather striping sits. Packed full of mud.
04-07-2002, 10:54 PM | #9 |
I did mine and made a couple of mistakes I hope you can learn from. First pay the few extra dollars and buy the GM ones. I didn't and the doors don't fit the rocker as well as they should. Pop the spot welds as a prior poster suggested on the front and rear of the rockers and under the lip that holds the weatherstrip. You will also need to separate the welds under the cab. Set the rockers WITH THE DOORS ON THE CAB. Don't miss that step. Use a weld through primer when welding the new ones one.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
04-07-2002, 10:59 PM | #10 |
Shortbox wanna-be.
Thanks for the info! I have a couple more questions though. What do you mean by weld through primer? Also how is it attached at the seams? Is that just caulked? What about where the rocker meets the cab corner, is there some sort of lips that you have to bend open first?
Sorry if this sounds stupid, but I don't have the new rocker to compare with yet, and I am just going by what I can see on the truck.
04-07-2002, 11:03 PM | #11 |
Mmm as I recall, the spot welds are only at the top lip and the bottom lip. The joint and the cab corner is just "floating" I think.
04-07-2002, 11:06 PM | #12 |
Weld through primer is a primer you spray on the backside of your work before welding to help prevent rust from reoccuring. Go to your local welding shop and ask them about it. You are right, there is calk in the seam where you can see the rocker joins the cab corner. (Below the VIN plate.) I used an air chisel to separate the welds. Just be careful you don't cut holes into the supports you are cutting the rockers from. I'm trying to think if I have any pictures that will help you, if I do I will e-mail them to you.
04-07-2002, 11:19 PM | #13 |
Repo - I e-mailed a couple of pictures that should help.
04-07-2002, 11:44 PM | #14 |
I just went thru welding in new rockers, toe kicks, outer parts of the front and rear floor panels, lower parts of the front and rear door jambs, removed and totally rebuilt the main rear support structure beneath the rear of the cab (a part that I think many guys are not aware of because I asked about this once on the board and got "1" response) and if you can restore yours with only new rockers you are fortunate. BTW to remove this rear support I had to drill out more than 70 spot welds. I'm hoping this will add another 35 years to the pickup. I almost forgot - new cab corners and I beefed up areas that I think GM purpously left weak.
[This message has been edited by hobby67stepside (edited April 07, 2002).]
04-08-2002, 06:30 AM | #15 |
Shortbox wanna-be.
Thanks for the info guys! I really appreciate it.
I also did get the pics. Thanks! As for cab supports, mine are all perfect. Just a bit of rot under the weather stripping, because mud had got in there. It could be fixed, but why? I am more for replacing than patching, so I am just going to replace the entire rocker and be done with it. Reid ------------------ Sylvan Lake, Alberta, Canada 1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. A/C, P/S, manual brakes. 75,800 Original Miles!! '71 Camaro SS 402/T400 resto '97 Z28 -- Runs 11.5 @ 118mph.
