12-16-2004, 12:44 PM | #1 |
carl
baggin my 1/2 ton
i willl be baggin my half ton in the next month comin up, i was wondering what trouble that i will occur on the way, i am sure i will have some issues. anything that i might not have thought about, stearing? crossmembers? and if so is where can i get these parts. i am riding on my stockies, 235/70r15 and i will also be pickin up some 2 1/2 inch drop spindles. what problems will i run in to?
a man and his truck, such a beautiful thing
12-16-2004, 01:47 PM | #2 |
Mike
Here is a good guide for bag instal .... http://67-72chevytrucks.com/vboard/s....php3?t=129463
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
12-16-2004, 02:23 PM | #3 |
carl
thanks thats really helpful but i was wondering also about clearance problems and such...? like technical problems that can occur durring or after the process? and things i need to look out for, but that was a sweet post, thanks man
12-16-2004, 03:54 PM | #4 |
Here's another good link. This site has some good info on it. webrodder.com
http://webrodder.com/article.php?AID=136&SID=5 Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
12-16-2004, 04:49 PM | #5 |
Head Peon
You may also want to check out www.bagginit.com it may contain some of the info you are looking for.
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
12-17-2004, 10:18 AM | #6 |
What year is your truck? On my 70 with the factory 6-lug wheels, they didn't clear the brake caliper after I switched to the dropped spindles & disc brakes. I assume that if it is a 71 or 72 with the 5-lugs you shouldn't have a problem. I had to go out and buy some new 6-lug wheels, after I told my wife that everything I needed was in the boxes that I ordered... it was not a good day.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 12-21-2004 at 12:12 AM. |
12-18-2004, 04:13 PM | #7 |
carl
really it didn't clear the rims. the package i was lookin at said it will fit the 15inch rims. huh dammit ok well we will see. thanks for the info. i will look into it.
12-18-2004, 04:41 PM | #8 |
carl
what about driveline problems?
12-20-2004, 08:33 PM | #9 |
I've explained the wheel clearance issue in this thread when I was ordering my dropped spindles. The aftermarket 15" wheels that I bought did clear, I'm just talking about the "original" steel wheels.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-20-2004, 09:37 PM | #10 |
carl
ohh ok right on thanks man
