12-27-2004, 09:02 PM | #1 |
lowering a blazer
what is the best way to lower a 81 blazer 2" in the rear?the front has 2"lowering spindles in it.I just do not like the rake it has.Thanks in advance Dean
12-27-2004, 10:39 PM | #2 |
67-72 parts collector,…
You can use a drop shackle for the rear leafs,... BUT it gets in the way of the gas filler neck. Are you sure your spindles are a 2" drop,... and not a 3"? Only other choice is a dropped leaf spring or removal off a few leaves from the pack. Do you have any pics of it?
12-27-2004, 10:46 PM | #3 |
I'm so sneeky I will post for him.......
It has 5 leaves in the back end |
12-27-2004, 11:06 PM | #4 |
Watch out for your cornhole !
Have the leafs dearched.
That's what we did on my Blazer.
12-27-2004, 11:11 PM | #5 |
any spring shop can do that?does it change the ride in it?thanks
12-27-2004, 11:21 PM | #6 |
Any spring shop can do it.
My local one charges right at 100 bucks to do it however low you want AND to replace all the bushings too (including the parts). We went 4 inches lower in the rear on my truck. It's lowered 5 in front.
12-28-2004, 12:08 AM | #7 | |
12-29-2004, 08:26 PM | #8 |
Got L.E.D.s
It can't be that hard to install trailing arms is it? That would be the best next to 4-link
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
12-29-2004, 08:37 PM | #9 | |
Happy to be here
12-30-2004, 11:11 AM | #10 |
belly dragger
My old 80 had a flip kit in the rear but I had to notch the frame dropped the rear about 6 or 7 inches and the front was down 6"
