Old 01-03-2005, 03:36 PM   #1
'70_402
'70_402's Avatar
How Do You Guys Do It?
How do you guys get a 12 volt source? do you put a blade type connector on the wire and push it inbetween the fuse and the holder? (i know it is kindof rigged up) basically what i am asking is, what is your method??
'70_402 is offline   Reply With Quote
Old 01-03-2005, 03:37 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
If I understand the question, I use cig or ignition unfused spades on the fuseblock, depending upon the application.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-03-2005, 08:56 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I just finished wiring up a relay that is turned on my the IGNITION UNFUSED terminal. This way I can run noumerouse things off this one terminal yet not over work the original harness.
Old 01-04-2005, 12:42 AM   #4
incoma
incoma's Avatar
I think this is a good question. What if you want to hook up the lighter light or glove box light, and want it to come on with the rest of your interior lights? Then you'd have to connect this to the "pnl lts" fuse, but what's the best way to do this?
I've seen special curved connectors that you can just slide inbetween the fuse and holder, but this doesn't look that clean to me. Any other preferred manner of doing this?
incoma is offline   Reply With Quote
Old 01-04-2005, 06:04 AM   #5
Longhorn Man
incoma, look on the pic above, under the CL of the word cluster feed.... that terminal is hooked to the dash lights. What ever you plug in there will dim or brightern with the rheostat with the dash lights.
Old 01-04-2005, 09:37 AM   #6
incoma
incoma's Avatar
Great. Thanks for pointing that out. I've looked at my fusebox and this picture several times and glossed over that little detail each time.
Old 01-04-2005, 12:06 PM   #7
Zonaman
Zonaman's Avatar
OK, but what'da do if all these are taken up?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 01-04-2005, 12:13 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
Absolutely no clue. My trucks are all stock with no added frills (or any frills for that matter). I subscribe to the KISS principal. I never have a question that isn't addressed by the factory GM manuals
I'm sure someone else can help ya though
