Old 07-03-2001, 08:07 AM   #1
nevada70chev
Post dropping my 70 c10
just got my c10 long box, it's completely straight and i want to do a 2/3 drop. can i do this with new springs&shocks or do i need new spindles up front? i'm on a budget and this is new to me. i want to be able to keep load capacity if possible. who do u recommend for a kit? any help is appreciated
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 07-03-2001, 07:27 PM   #2
cdwhzk
Post
Yes you can do the 2/3 with springs and still have a good load capacity. go to the suppliers on the home pagr they all have what you need WES at HEARTBEAT,GMC PAUL,MOTHERTRUCKERS all sell good quality stuff and can help you out
71c10 350/350 air ps pb 320hp crate 2004R tranny from FB performance 410moroso posi completely rustfree body
27T coupe chopper 6.5 inches channeled total height 41inches powered by bigblock Edsel punched out to 490ci topped with 6stromberg97's built back in 67
Whizzer motorbikes 6or7
71C5 Blazer 350/350 needs rust repair but runs new
74Pinto stationwagon daily driver
cdwhzk is offline   Reply With Quote
Old 07-04-2001, 01:24 AM   #3
nevada70chev
Post
thanks for the info. will i have to worry about front alignments etc.
Old 07-04-2001, 09:43 AM   #4
racedvl
racedvl's Avatar
Cool
I would personally go with a drop spindle in the front. It does not change anything in the suspension but where the centerline of the wheel is on the spindle. You can then use factory springs, shocks, ect. When I do mine I'm gonna use drop spindles and lowering blocks for the back. This way I don't have to worry about getting speical springs, shocks, and what not. Just my .02
http://hometown.aol.com/racedvl/racedvl69index.html
Crystal Lake IL. 30 Miles north of Chicago
racedvl is offline   Reply With Quote
Old 07-06-2001, 02:29 PM   #5
nevada70chev
Post
Will you be doin it yourself? Also what is the cost? I looked at Early Classics, they have a 2/3 drop kit that is coil springs and shocks. Are you getting a kit or do you have to build the parts list? Thanks for the input.
Old 07-07-2001, 12:15 PM   #6
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
also with drop spindles you can convert to disk
but yes you can do a 2/3 drop with just springs and shocks no problem
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 07-08-2001, 10:18 AM   #7
fleetimus
fleetimus's Avatar
Post
This drop was done with 2.5" spindles from Early Classics. I also cut one coil. The rear is 4" springs. I haul a car trailer and a boat. I also replaced the front with a complete xmember from a 75 1/2 ton.
If you have any questions. Send me an e-mail.
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 07-09-2001, 02:49 PM   #8
LeRoy
Registered truck nut
LeRoy's Avatar
Lightbulb
Something to consider. I just put a 2-4 drop on my buddies 66. Do to his old springs sagging, after putting in the new drop springs it only lowered the front 1/2" and the rear 2".
MOUNT VERNON, WASH. STATE
GOT MY BASES COVERED
-Big and bad 70 CST Blazer
-71 K5 Blazer, 350, 4spd
-Work in progress 72 SWB
-72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd.
-71, 3/4 ton, 402/400, Custom Camper
-69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER"
-69 Chev., lwb, utility trailer, 35" tires,
-88 1ton BB workhorse
Add or Delete Daily
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 07-15-2001, 10:52 PM   #9
drodgers
Post
i talked to gmcpaul at carlisle about springs and he said the same thing.he recomended finding a restored truck like yours and measure from wheel opening to ground and comparing it to yours to check how much it's sagged befor buying springs sometimes a 2" drop spring will actually raise an old truck because it had sagged 3" from original height!
drodgers is offline   Reply With Quote
