Old 09-15-2001, 07:42 PM   #1
TonyZ
Post 94 torsion bar adjustments
Can the front height of the truck be adjusted by the torsion bars? If so can someone send me a link to a descrption of how to do it,or explain. Thanks Tony
TonyZ is offline   Reply With Quote
Old 09-16-2001, 01:06 AM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
there are bolts underneat that you tighten which raises the front of truck up to 1 1/2" i think.... it will put more stress on your suspensien it will ride like crap and wear out faster though
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 09-17-2001, 12:28 AM   #3
Z16
Post
The torsions are used as part of the alignment process for leveling the truck. As you raise a truck you effectively increase the spring rate, creating a stiffer ride, and if you lower the the truck you decrease the spring rate giving a softer and somewhat bouncier ride. This is not an optimal way to change the suspension height, but will work for small adjustments of up to 2". If you want to go up, you are best to use a lift kit, or if you want to go down, use Bell Tech's lowering keys, then use the torsions for minor adjustments to get the truck as level as you want. To adjust, find the bolts located at the rear of the torsion bars, on either side of the transmission, and simply turn them a little at a time in the direction you want to go until you reach desired height. Be forwarned, adjusting one side will have a height effect to the other side.
98 GMC Sierra Ex Cab, cowl hood, Euro lenses, billet grille, cat-back exhaust. Airbags, 18's, and engine mods in the spring. Looking for the right 71-72 GMC short/fleet
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now).
95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver
Z16 is offline   Reply With Quote
Old 09-17-2001, 12:07 PM   #4
TonyZ
Post
Thanks guys, It's a leveling adjustment I am looking for, not a lift. This should help me out. Tony Z
