Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 01-15-2005, 07:34 PM   #1
bigstew
need help with a ford(sorry)
my driver right now is a 81 bronco, but just until i get my sub going. but i need some advice on the wiring. i have put a new alternator, new battery, and a new voltage regulater on it. the problem is the alternator will not charge the battery. i just got the alternator tested and it is putting out 15 volts. when it is in the bronco it is only putting out 11.50 volts. what else could be the problem? im real close to fixing it with a rag in the gas tank and setting the rag on fire.thanks
bigstew is offline   Reply With Quote
Old 01-15-2005, 08:05 PM   #2
bisquik65
bisquik65's Avatar
Switch the 2 wires that push on the rear of the alt. That should do it. Common problem with a motorola alt and of course F*rd. I have a 84 mercury marqui wagon with 62,000 miles and a rod ready to fly, so i picked up a 89 cougar at the local auction for $125 . hit in the front See pic. and guess what ? It has the 3.8 supercharged motor in it. I see hot rod sleeper wagon.!!!!!!!!!!!!
bisquik65 is offline   Reply With Quote
Old 01-15-2005, 11:01 PM   #3
68LSS1
68LSS1's Avatar
Check the fusible links off of the solenoid.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 01-16-2005, 12:59 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Put a cherry bomb in the gas tank and run like he!!...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-16-2005, 04:21 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
72 Custom Camper is on the right track, LMFAO though. It sounds like its grounding out some where probably beacause its a fo*d, no it is probably just grounding out somewhere. Check the wires to make sure they are not frayed and make sure you have the alternator belt tight.
-Peace
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-17-2005, 12:17 AM   #6
Florida Mike
Take a second look at that voltage regulator if all else fails, I used to work
at a parts house, those things were good for all sorts of problems. They will commonly stick causing you to have a dead short ( constant drain on the battery)....Good luck
mike
Florida Mike is offline   Reply With Quote
Old 08-14-2005, 01:52 AM   #7
fde2blk
[/B][/U]no ford letter words
fde2blk is offline   Reply With Quote
Old 08-14-2005, 02:47 PM   #8
farmaller
farmaller's Avatar
Also check the condition of the wireing, look for any crushed or rubbed threw spots that might have cause the wire to corrode, I had this happen a couple of times.
Currently helping a Friend build a 71 Custom Camper into his dream truck
Guess that makes me the Middle man since he asks questions and I search for the answers
farmaller is offline   Reply With Quote
Old 08-14-2005, 02:58 PM   #9
cableguy0
those old trucks are a fire waiting to happen as far as wiring goes. start tracing wires and looking for burnt spots or melted spots. also while your at it with the wiring nightmare take apart the bulkhead connector between the under hood and under dash unit and make sure none of the connections there are fried. dont be surprised to see a melted bunch of plastic and wires
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-14-2005, 08:47 PM   #10
squizzleboy
I agree. Put the rag in the tank and light it.
63 chevy
350 crate
th350
silverado seats
american autowire harness
squizzleboy is offline   Reply With Quote
