Old 03-08-2005, 11:33 AM   #1
dmec
dmec's Avatar
van tilt column ?
is it really necessary to relocate neutral safety switch when installing a van column in these trucks?
dmec is offline   Reply With Quote
Old 03-08-2005, 01:09 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes it is. Otherwise, the column won't bolt in. It interferes.
Old 03-08-2005, 01:26 PM   #3
Livrat
Member #1049
Livrat's Avatar
Not on all van tilts.. the early ones.. 70 - 73 have the neutral safety switch in the correct location and even have the correct levers.. the only change necessary on them is the shaft length...
Livrat is offline   Reply With Quote
Old 03-08-2005, 06:15 PM   #4
uncle
Switch
You can remove it, but your truck will start in any gear.
uncle is offline   Reply With Quote
Old 03-08-2005, 07:08 PM   #5
dmec
dmec's Avatar
thanks for the info. i have 6 columns i plan on rebuilding for sale and didnt know if relocating switch was neccessary. the collars that have loose pins are going to be shaved and turned into floor shift models. i just did a floor shift model for my truck. i shortened the mast 2 inches to get the steering wheel out of my face. much better. i can even see my bottom gauges now.
Old 03-08-2005, 07:27 PM   #6
dmec
dmec's Avatar
my shortened floor shift tilt.
Old 03-08-2005, 07:35 PM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Yeah they are much more comfy shoved down in there like that.I left mine up about 2 inches farther than that,but it's much better than a stocker.
I don't have a place for my tach now until I work on the dash
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-08-2005, 07:44 PM   #8
Big Block
Big Block
Big Block's Avatar
I saw your tach is 7 grand, What is it out of? Is that a early camero tach? I saw one at a venders display at Charlotte NC auto fair. Thanks B.B.
Big Block is offline   Reply With Quote
Old 03-08-2005, 08:15 PM   #9
dmec
dmec's Avatar
yes it is a camaro tach. here is 1 i put in another dash. i also used 80,s truck gauges.
Old 03-08-2005, 08:28 PM   #10
Big Block
Big Block
Big Block's Avatar
Does it work with the stock printed curcit board? Do you have to make any mods. to make it fit? Thanks B.B.
Old 03-08-2005, 08:43 PM   #11
dmec
dmec's Avatar
yes it works with the stock printed circuit. there is a trick to it and if i told you i would have to kill you. LOL. just kidding. tried to load picture of back but file is too large. send e mail and i could show pic.
Old 03-08-2005, 08:51 PM   #12
shifty
Questionable
shifty's Avatar
If you're using Windows XP, find the actual file on your computer, right-click the file and choose "Edit".
This should open it in MS Paint program.
From the 'Image" menu, choose Stretch/Skew. Change the numbers to be 50%horizontal and 50% vertical and click OK.
This will shrink the dimensions by half. From the 'File' menu, choose "Save as" and save the file as a JPEG with a different name.
The board should let you upload it without a problem.
If it's too small to see the details, you can try doing a 75% shrink.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
