Old 06-11-2002, 08:26 PM   #1
HYPERMAN
Dual Exhaust Set Ups?
I am ready to install exhaust on my 68 Short Step. It has a V8 with both ramhorns curling back.
I would like to know what you guys run...pipe size, offset/center exit/enter on mufflers, exit before wheels or at back.
What is the proper size for the ranhorns?
Any pictures would be cool.
I am leaning to exiting before rear wheels
PS...I am running a poly blazer tank in the rear.
thanks for any and all info.
Peter
HYPERMAN is offline   Reply With Quote
Old 06-11-2002, 08:35 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My stock ramhorns are 2" outlet. I'm replacing them with vette ramhorns in a couple weeks, they have 2.5' outlet. I'm going to run 2.5" pipe through chambered mufflers and exit before the rear wheels. As far as the mufflers go they are reversible with one end centered and the other offset. I guess the muffler man would run in the center side and out the offset side with the offset down. If that makes any sense. My ramhorns exit down as do the vette ones I'm installing. But I believe your swept back ones are 2" also. Someone will correct if I'm wrong.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-11-2002, 09:10 PM   #3
JReynolds
Thumbs up Exhaust pictures
I hope this picture will be helpful. I don't have the ramhorns, I used ceramacoat headers, but the same principals would apply. I used 2-1/2" aluminized, ran the pipe over the rear axle, tricky bends with the trailing arms & shocks, but a good exhaust man can do just about anything. I used 2-1/2" Summit turbo mufflers, but I dont have to worry about rust, as this is strictly a pleasure craft. If it was going to see bad weather, I would have gone with stainless. Again, hope this picture helps.
1969 SWB Stepside. 350 w/Vortec heads, 380 H.P., 450 ft/lb dyno proven.
JReynolds is offline   Reply With Quote
Old 06-11-2002, 10:26 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You just can't go wrong with side pipes man.
Old 06-11-2002, 11:22 PM   #5
Mike C
Mike C's Avatar
On the JImmy I have 2 1/2" rams horns, 2 1/2" mandrel bent tubing and Dynomax Hemi Turbo mufflers. It has pipe exits behind the wheels that are 45 degrees to the frame and have slash cuts on the end.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-12-2002, 11:02 AM   #6
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
Love the plate JR CLASSIC
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 06-12-2002, 12:57 PM   #7
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Mine's got 2" stainless from the original header pipes back..with stainless glasspacks.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 06-12-2002, 04:06 PM   #8
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
i have dual 3'' w/ flowmasters and h-pipe that exit the rear w/ a poly tank. its a tigt fit over the rear axle w/ 2.5'' drop. the tail pipes are turned down and tucked behind therear bumper
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 06-12-2002, 04:31 PM   #9
zardiw
Faster horses, yw, ow, mm
Whatever you use, I'd get the X crossover from DrGas.com. It'll get ya 15 or so extra ponies, plus make it sound really COOL.........z
'73 C20, 383, 3500 leaf springs, 38.5 Mickey Thompson Baja Claws (More ground clearance than an H2 Hummer), Performance Distributor (Tits!!) w/Clear cap (awesome at night), Edelbrock intake+IAS shocks, Tri Y headers, Dr. Gas Xover(for that NASCAR sound).
zardiw is offline   Reply With Quote
Old 06-13-2002, 01:57 AM   #10
jhwkns
Registered Cruiser
jhwkns's Avatar
I'm using Flotech headers. 3" collectors into 2.5 pipe, turbo mufflers about 3' behind the collectors, and exiting before the rear wheels. The total cost was about $275 including the headers. It works, and sounds great.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
