06-11-2002, 10:01 PM | #1 |
biulding a 1/4 mile 7 second truck
I saw a 72 in hot rod (i think) about 10 yaers ago. it was a lwb , it wasnt choped ,just tubbed and had a big block. he was running the 1/4 mile in the 7s. it was awsome!!!!! my next progect is to biuld a truck like that. I would like to know what i should use for rear suspention, ( 4 link or ladder bar).I am going to start out with a sb till I can aford the big hp bb. any more info on a drag truck would be cool.
maybe the guy with the 7 second truck is on the board some where? |
06-11-2002, 10:17 PM | #2 |
check dragtruk.com
there are a couple of trucks running those times. I believe they are on the stock rear suspension.
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
06-11-2002, 10:19 PM | #3 |
So Many Ideas, So Little Money
I'd say 4 link, much mroe adjustability. just a thoughtfor down the road too, if you wanna hook up you need te chassis to have a good rake, not te body, the chassis, yu look at prostock, it looks all low, but thats jst body, the frame isat a goodrake, you need that or you'll smoke em orever, jsut a lil. teahin lesson early on.
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
06-11-2002, 10:29 PM | #4 |
Hi Crew 70. Check out dragtruk.com. Most of the 67-72s are running bb and have stock but topped trailling arms with coil over shocks. I have a 2 bolt 454 done for $400 can make 700hp with 2 bolt. Let me know.
06-11-2002, 10:36 PM | #5 |
chevy2race what do you mean by rake and generaly how much 3 degrees ,5, 10 ??
06-11-2002, 10:41 PM | #6 |
06-12-2002, 12:56 AM | #7 |
awsome truck
try searching for "joe delahay" first truck to do 200 mph, its a wild looking Truck and hes from Canada to, awsome photos of one of his nitrous fries and when his truck doors blew off at 200 mph or sumthing, crazy!
06-12-2002, 08:42 AM | #8 |
7's will take at LEAST 1200 hp in a 3000# vehicle. Maybe more. My buddies 90 Camaro ran 8.67 @ 163. It dynoed 850 hp on the motor and had a 400 shot of nitrous, it wasn't quite sorted out before it was totaled, so it would have gone faster. It IS possible to get a truck to run that, but you need to get some solid advice from a professional chassis builder. Plan on spending around a minimum of $10,000 for a long block plus a large plate type nitrous system and another $10,000 for a back-halfed chassis with roll cage. Like everything else, add 50% for cost over-runs This little truck runs low 8's with a 460+" SMALL Block. He's been racing it for at least 15 years.
06-12-2002, 12:57 PM | #9 |
awsome!!!!!!!!! drauling heavaly
06-12-2002, 01:25 PM | #10 |
crew it is decked line honed bored with toqure plates hope that helps Fl east coast
06-12-2002, 01:35 PM | #11 |
CCRider
WOW a Chevy truck running 7's with the stock rear suspension.
What size jet engine is mounted in the bed?
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
06-12-2002, 05:45 PM | #12 |
that dragtruk.com is cool there are some fast 67-72 trucks on there . 8-9 second trucks . one is for sale ? maybe I should save me some time and just by it? $27000.00 maybe not . although I wish I could.
