Old 06-11-2002, 10:28 PM   #1
flyin99
creator of kong
flyin99's Avatar
What are these 3 wires in my engine harness?
I just want to make sure where these go...........
flyin99 is offline   Reply With Quote
Old 06-11-2002, 10:50 PM   #2
Benrs86
Benrs86's Avatar
is that a aftermarket wiring harness? it looks nice. i think green is water temperature sender. red maybe your automatic choke? dont know, im just guessin about the red one, but pretty sure that originally the temp sender wire is green. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-11-2002, 10:58 PM   #3
Zkast
Zkast's Avatar
Cory M has a diagram on his site that might help you...
http://www.geocities.com/chevroletc1070/wiringdias.html
The blue wire is for an oil pressure sending unit.
The Green wire's I believe are for AC compressor and Soleniod. Or for a temp sending unit near the thermostat housing ( Gm used green for both ac (light green) and temp sender wires(dark green)
The Pink hmmm nothing comes to mind right off hand. Possibly your old ignition coil + supply wire?
Zkast is offline   Reply With Quote
Old 06-11-2002, 11:04 PM   #4
Blue_71
Bloo
Blue_71's Avatar
i THINK green is temp, blue no clue, and pink no clue, but i do know that there not on my 71s harness. BUT they were on a 70 harness i had
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 06-11-2002, 11:05 PM   #5
flyin99
creator of kong
flyin99's Avatar
I did buy it new.it is one of those M&M harnesses, that GMC Paul's sells......My factory harness didn't have an oil pressure light, or it had been cut......I am running gauges.....as for the pink one....this one is really confusing me......if it is laid out right............this wire wants to go to the front of the motor somewhere.......I dunno...........lol.......thanks for the help though
Old 06-11-2002, 11:11 PM   #6
Benrs86
Benrs86's Avatar
get a voltameter, and figure out when it gets power, like with the key on, or put some volts to it and see if a guage moves? maybe that isnt a good idea. good luck tho, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 06-12-2002, 12:00 AM   #7
Mountain Man
The blue or the red wire might be the electric choke wire.
The green wire may be for a tach.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 06-12-2002, 06:57 AM   #8
tom hand
CCRider
tom hand's Avatar
If it is a stock harness I think the red one is for an anti-deseling solonoid that goes on the stock quadrajet.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-12-2002, 03:55 PM   #9
rustfree
I went with M&H also and had the same questions. This is way it goes. There are 2 green wires for temp sender. One plug works with warning light type sender the other works on gauge type. The pink/red goes to the solinoid on q-jet carb and the blue would go to oil pressure sender if you only had warning light and not gauge. I just cut off wires not needed and went with it.
BTW M&H uses only factory color/gauge and connectors in their replacement harness's, just the way it should be!
72 swb cheyenne super 350/350
69 cst20 BB longhorn
Warren, OR
rustfree is offline   Reply With Quote
