Old 06-13-2002, 12:01 AM   #1
GMC1967
Question Urgent Engine Rebuild Problem!!!
I just tried firing up my 1967 292 L6 that I had rebuilt, and it wouldn't turn over. I thought the starter was bad but then I noticed some water (thats right water) leaking from one of my spark plugs, I tried turning the engine over again with the sparkplug removed and water fired out of it like a firehose. I removed all the plugs and then cranked it again, and water is firing out of all cylinders. What is going on? I just had this motor rebuilt, why is this happening? Just trying to get some ideas before I go over to the machine shop tomorrow and raise hell. I'm wicked pissed, good thing that shop isn't open tonight....
GMC1967 is offline   Reply With Quote
Old 06-13-2002, 12:01 AM   #2
REPO1
Shortbox wanna-be.
REPO1's Avatar
Sounds like you have the wrong head gasket on it.
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 06-13-2002, 12:08 AM   #3
breeh
Recovering 67-72 Addict
breeh's Avatar
Head gasket was my first thought as well....
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-13-2002, 12:41 AM   #4
bigvinnie
bigvinnie's Avatar
sounds like you either have the wrong head gasket, no gasket at all, or the head is not torqued down properly.... bummer.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 06-13-2002, 12:56 AM   #5
jhwkns
Registered Cruiser
jhwkns's Avatar
I sure hope you didn't bend anything
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 06-13-2002, 01:10 AM   #6
zardiw
Faster horses, yw, ow, mm
Might be a defective head. One time I bought a rebuilt 292 for my C60, and (B4 I put it in LUCKILY), I noticed an actual hole next to one of the plugs that was going into the water jacket!!! .........z
'73 C20, 383, 3500 leaf springs, 38.5 Mickey Thompson Baja Claws (More ground clearance than an H2 Hummer), Performance Distributor (Tits!!) w/Clear cap (awesome at night), Edelbrock intake+IAS shocks, Tri Y headers, Dr. Gas Xover(for that NASCAR sound).
zardiw is offline   Reply With Quote
Old 06-13-2002, 08:23 AM   #7
GMC1967
Thanks guys, I'm hoping it's just the wrong head gasket.
1967 GMC Custom 8ft Fleetside 292 L6, 4spd.
1973 Oldsmobile Delta 88 Convertible 455, TH 400
1969 F#$% Bronco 302, 3spd 4.11's
1958 Oldsmobile Super 88 Fiesta Wagon
Old 06-13-2002, 11:38 AM   #8
RodC
RodC's Avatar
Get the water out of it, with water in the cyl the rings can seize up in a matter of hours. After you get all the water out get some oil in those cylinders to keep the rings/walls from rusting.
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 06-13-2002, 12:42 PM   #9
GMC1967
The engine shop is convinced it's not the headgastket, although they won't come out and look at it. I think I need to take the head off, but I don't know what i'm looking for, any ideas?
Old 06-13-2002, 01:00 PM   #10
RodC
RodC's Avatar
If it is the wrong head gasket, the ports that allow water to flow from the head into and out of the blocks water jacket will not line up.
Did the machine shop torque the head down or did you?
If they installed the head, you may have a problem collecting on any warranty after you remove the head.
Rod Childers
'71 C10 Stepside
Old 06-13-2002, 01:42 PM   #11
Desert Rat
Desert Rat's Avatar
Definanetly head related/gasket.Get that antifreeze out of your motor/bearings.If they are sure not headgasket im assuming they put it on.Wonder if torqued it?Did they adjust valves etc,or you?
Desert Rat is offline   Reply With Quote
Old 06-13-2002, 03:28 PM   #12
GMC1967
They put the headgasket on, they did the initial valve adjustment, they told me I had to redo them once it started but that's normal. Basically these guys are blowing me off, so it's up to me to do something here. I'm still banking on the headgasket, and oh yeah, they supposedly torqued the head also. How can I be sure I have all the water out?
Old 06-13-2002, 03:51 PM   #13
lukecp
Formerly yellow72custom
lukecp's Avatar
I wouldn't be too happy about that at all.....i would go talk to the owner of the shop and raise a little hell. Whatever the problem is, it is almost certinaltyl their fault, since they built the motor.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-13-2002, 04:02 PM   #14
GMC1967
Does anyone know if the headgaskets changed through the years? The guy at the machine shop is telling me that they are all the same from 1963-1978. This may be true, but they definately made 292's after 1978...
Old 06-13-2002, 04:39 PM   #15
68 Stepside
huh?
68 Stepside's Avatar
If they did all that stuff for you, shouldn't you have an agreement of some type, or reciepts? I wouldn't touch it if you do, and I'd either A. Talk to the manager of the shop, and if that didn't work B. Sick the law on them. I'm not a big fan of plan B, but if they did the work, and they're now blowing you off, go for it.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-13-2002, 04:48 PM   #16
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
It is not up to you to fix the problem unless they did the job for free.
If you paid them to fix it, then they should fix it or refund all your money!!!!!!!
Regarding the water in your engine. Drain your coolant (lower raditor hose works.
Then change the oiland filter. REFILL oil, Squrt a little oil in the cylinders. you can leave the plugs out. turn the engine over till oil pressure comes up and then some more to flush the water out of the bearings.
Good luck,
Denny
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 06-13-2002, 04:49 PM   #17
jamiew
I don't know about anybody else, but I expect quality work when I pay a machine shop to do it. There is no way I would touch a head bolt in that engine. I would take it back and raise all kinds of hell with the owner, especially if they were blowing me off. If that didn't work, there's always the better business bureau. It makes me mad and it happened to someone else. just my 2 cents.
jamiew
jamiew is offline   Reply With Quote
Old 06-13-2002, 07:09 PM   #18
jhwkns
Registered Cruiser
jhwkns's Avatar
I hope this helps
You might be able to diagnose your problem by pressurizing the cylinder that had the water in it. Make sure it's leaking down before you disassemble the engine. The water might have gotten in there through your intake. If so there might be no problem at all with your motor. Good luck, John
Old 06-13-2002, 07:13 PM   #19
jhwkns
Registered Cruiser
jhwkns's Avatar
Oh by the way, I realize that a 292 has an integral head. It is possible that some fluid got int the intake before you ever got the motor from the machine shop.
