Old 06-13-2002, 06:26 PM   #1
bluzman2004
FOR SALE: Vortec Heads
Sorry this is the wrong board for this, but I have recieved some helpful tips on here so I wanted to give you guys first dibs.
I have a brand new, in the box fully assembled, set of Vortec heads for sale. I bought them for my new motor, but now I can't use them. My block had been decked before so, now my compression would be too high with the 64cc chambers for my blower. I would like to get my money out of them $500 or I would trade for a set of used aftermarket heads with larger chambers.I will take a decent offer, too.
69 Chevy ProStreet, Low and wild.
78 Corvette
rturnpaugh@compcams.com
bluzman2004 is offline   Reply With Quote
Old 06-13-2002, 06:44 PM   #2
Benrs86
Benrs86's Avatar
woudl they fit the original block in my 69? it is decked .010 and is a 350 bored .030. thankss, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-13-2002, 06:56 PM   #3
bluzman2004
These heads will bolt directly on your sbc. You would only have to buy the edelbrock intake for Vortec heads. Nothing else needed. Also, I actually flowed one on the flowbench and they flow what AFR says they do. 239cfm on the intake. You have to spend almost $1000 on a set of heads to get that. I am impressed by the Vortec heads.
78 Corvette
Old 06-13-2002, 07:09 PM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
You will also need center bolt rocker covers with the Vortec heads
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 06-13-2002, 09:47 PM   #5
mikep
Used to have a truck
mikep's Avatar
You need different rockers and valve covers for the vortec heads in addition to the manifold. Also arent they 58 cc chambers instead of 64 cc? Even with flattops that would put your compression well over 10:1. Theyre good heads but the motor must be built for them.
I'd probably trade you for my 72cc chamber sportsman II's but I'd have to change pistons too and my ratating assy is all balanced and it would screw that up.
No truck :-(
mikep is offline   Reply With Quote
Old 06-13-2002, 09:57 PM   #6
lux hauler
Psycho-billy Member
lux hauler's Avatar
Vortecs are 64cc
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 06-13-2002, 10:04 PM   #7
bluzman2004
They are definately 64cc. The fastburn aluminum vortecs are 58cc. If you run a flattop piston with a .039 head gasket and a standard deck height, you get about 9.3 to 9.5. Standard deck height is about .020". My problem is my deck is .003, I'm at about 10.25.
I could use a 72c head, that would put me in the low 9 range.
78 Corvette
Old 06-13-2002, 10:21 PM   #8
fnoblitt
fnoblitt's Avatar
how about changing the pistons to the dished top for a lower ratio ?i know that could be a hassle if your block is already done. i hate to see you part with a *****en set of heads.
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 06-13-2002, 10:34 PM   #9
mikep
mikep's Avatar
I didnt realize the iron heads were 64 cc. With my pistons It would put me at 11:1 which is too high for my blood. My next engine build will probably use vortecs though although I dont have any complaints about the sportsman II's .
No truck :-(
Old 06-13-2002, 10:49 PM   #10
bluzman2004
You must be running a .100 dome piston. That would be tuff on gas unless you were at my altitude 6000ft. I run 11.5:1 in my corvette. I runs good on 91 octane here.
78 Corvette
Old 06-13-2002, 11:07 PM   #11
mikep
mikep's Avatar
Yeah, I run .125" dome speed pro hypereutectics. It would put my compression a wee bit on the high side for 92 octane at sea level where I live.
No truck :-(
Old 06-14-2002, 12:30 AM   #12
TheMattMan
From all of my research the last months the heads are definently 64 cc and a set of flattops with 4 brow reliefs will give you about maybe 9.4(9.6) : 1 compression and 2 brow reliefs should give a 10:1 compression.
TheMattMan is offline   Reply With Quote
Old 06-14-2002, 03:24 AM   #13
67wyo chevy
jim pace parts have the conversion for 745 includes heads assembled and intake and gaskets evrything even the sparkplugs
67wyo chevy is offline   Reply With Quote
Old 06-14-2002, 05:11 AM   #14
68 Suburban
68 Suburban's Avatar
67wyo chevy, I know you are trying to be helpful, but I think the proper board edict would be not to post comparable price options on someone elses "For Sale" post. Just a thought
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
