Old 06-13-2002, 11:07 PM   #1
bluzman2004
Angry Window Rattle
What does it take to get rid of the window rattle? Is there a kit to replace all the guides or something?
69 Chevy ProStreet, Low and wild.
78 Corvette
rturnpaugh@compcams.com
bluzman2004 is offline   Reply With Quote
Old 06-13-2002, 11:36 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Replacing the inner and outer bell weather strips usually takes care of the rattle. If not then new window channel front and back will. GMC Paul or any of the other vendors sell the kits and individual pieces. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-13-2002, 11:40 PM   #3
bluzman2004
It only rattles when it's down. There's alot of movement in there. I guess i'll look at GMC Paul's site. I've ordered from him before was very happy with the service.
Thanks,
78 Corvette
Old 06-13-2002, 11:46 PM   #4
bluzman2004
Thanks,
78 Corvette
Old 06-14-2002, 12:37 AM   #5
BIG ORANGE
BIG ORANGE's Avatar
Wink window rattles
You need the super kit that takes care of all the weatherstripping in both doors and will put you back good as new.Check out KINGPARTS.COM they have great prices on there product,and tell them your from the board,hope this helps
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 06-14-2002, 07:14 AM   #6
tom hand
CCRider
tom hand's Avatar
I know I am going to hear it on this one, but here goes. Every one of these trucks I have owned rattled when the window was down except one, a 72. For some reason GM put a screw in the door, in 72 only, right where the rattle was coming from. Coincidence?
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-14-2002, 07:57 AM   #7
MOTHERTRUCKERS
After you put the new division bar,channel and inner-outer glass seals in if they still rattle pull your vent window out and weld the metal strap that holds the inner-outer door together. If there is a crack or break at the top of the door by the vent window running down you need to pull the door,dissamble it and weld a strap accross it inside to prevent more metal fatigue. Just welding the break will not work it needs a backing plate welded inside to stop the vibration that will in time fatigue and break the metal around the top door hinge. When we repair them here we take a 4" long x 2" tall piece from the top rear of a donor door and weld it into the cracked door then weld a 12" long x 6" tall backing plate in to prevent any more vibration fatigue. Don't forget the clip slot needs to line up with the inner-outer clips. (spelling?)
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 06-14-2002, 08:48 AM   #8
bluzman2004
Thanks for the info. I need to replace the weather seals anyway, so I will shop around for the kit.
78 Corvette
