Old 06-15-2002, 09:24 PM   #1
chevyman 68 C/10
chevyman 68 C/10's Avatar
Question will 73 up gears work in 67-72 and visa versa
Just want to know if I can put gears from my 69 -3.73 in a 73 up posi-tract housing:
chevyman 68 C/10 is offline   Reply With Quote
Old 06-15-2002, 10:44 PM   #2
Mike C
Mike C's Avatar
If both rear axles are 12 bolts and if both are the same series. 3.73 and up requre a 4 series carrier in trucks and less than 3.73 is a 3 series. If you want to put 3.73 on the posi and it is 3.07 you can buy a thick gear from Richmond. That's the way my 4.10s are, mounted to the original 3.07 Eaton posi in my JImmy.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-16-2002, 06:21 PM   #3
chevyman 68 C/10
Hey, thanks Mike for the info . I never had any idea the ratio had any thing to do with it.
Chevyman 68 C/10
