Old 05-29-2005, 02:17 AM   #1
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
68 K10 drivetrain questions
What front end should be under this truck? I'm thinking it is a closed knuckle Dana 44.
Also, what 4 speed and transfer case was used in 68?
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 05-29-2005, 07:10 AM   #2
Blazer1970
Blazer1970's Avatar
You are correct on the front axle.
4 speed would be a SM420 (reverse down and to the left) and the t-case is a Rockwell T-221. The Rockwell is easily identified because the rear output is a few inches lower than the input. I believe '68 is the only year for a married 465/221 combo.
Blazer1970 is offline   Reply With Quote
Old 05-29-2005, 01:24 PM   #3
HugrOrang71
Bite me, import boy
Thank you very much.
Jason
Old 05-31-2005, 12:33 PM   #4
Hawged-67
i had a 68 k20 with the 44 closed knuckle 17.5 wheels, it had a rockwell T-221 and a SM 465 (reverse down to the right, not left.
'67 chevy on '79 K10 frame
Metallic Grey-Fleet White top
35in Ground Hawgs
355 ci, SM 465, NP 205
"A Dying Breed...Classic Chevy"
Hawged-67 is offline   Reply With Quote
