Old 06-17-2002, 04:20 PM   #1
ty1295
6 lug to 5 lug changeover list
Can anybody confirm the req'd parts to change from 6lug to 5lug?
I have for sure
lower a arm
spindle, brakes, dust shields, on out
rear axles
and drums
changing over my 70 GMC, have all the parts, but have to have them shipped 2600 miles, so trying to only ship the req'd stuff.
Are the backing plates on rear the same?
What about tie rods, I assume they are the same.
Anything I am missing?
Jeff
Jeff Scott
'70 GMC Stepside, Short box
'63 Nova
'92 GMC typhoon
'95 Tahoe
ty1295 is offline   Reply With Quote
Old 06-17-2002, 11:06 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
you need the ball joints and tie rods for a disk brake truck
68SWB4x4 is offline   Reply With Quote
Old 06-17-2002, 11:16 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
all you need are shafts and drums for rear, i have all for 30 plus mail, from running truck if interested anytime soon.
front you will be best off to find a complete suspension from a 71-87 truck. preferably 79 at latest.
is direct swap over, the brake lines run on front side of cradle on 71pup and run behind it on pre-71 trucks, have to re-route all lines and hoses for later model and get brake proportion valve off a 71-up truck, and correct pitman arm and i prefer 73-up hoses because they are lots longr and pass through frame rail holes instead of having to worry about having to fab brackets to mount them in on the 64-70 cradles, calipers differ from 72 to 73 and so do hose ends,.
good luck
Fast68Chevy is offline   Reply With Quote
Old 06-18-2002, 05:51 PM   #4
jamiew
I agree with ty1295, you should get the entire front cradle from a 73-87 chevy/GMC. I did the changeover on my 64 and it was relatively simple. Got the front entire front suspension from a rear wrecked vehicle. Cut the frame just behind the shock mounts and it bolted right up with little effort. On your 70 GMC, you will have to "egg out" the lower side frame mount holes as the 73-87 has a narrower bolt pattern. If you use from 80-87, you will have to drill another hole in the top side mount holes also. Everything else is a bolt on. Changing the entire cradle is the way to go. Makes it much easier to order parts and you don't have to mix and match parts. If you do the entire swap, be sure to get all the front brake lines and bolts from the donor vehicle. Best way is to have them cut the frame. Good luck whatever you try.
JamieW
jamiew is offline   Reply With Quote
Old 06-18-2002, 06:16 PM   #5
DR67
DR67's Avatar
I guess I am missing something, what is the advantage of 5 lug over 6 lug.
Dave
Knoxville,Tn.
DR67 is offline   Reply With Quote
Old 06-18-2002, 09:43 PM   #6
bbs1965
Open Sundays 10 till 10
wheel selection
bbs1965 is offline   Reply With Quote
Old 06-18-2002, 09:50 PM   #7
Tim Christian
Tim Christian's Avatar
Smile
But now wheel selection is great for 6-lug! IMO
Tim Christian is offline   Reply With Quote
Old 06-18-2002, 11:03 PM   #8
racedvl
racedvl's Avatar
And disk brakes!!!
racedvl is offline   Reply With Quote
