Old 06-17-2002, 09:45 PM   #1
HeavyK20
HeavyK20's Avatar
Question Engine Balancing Q?
I have a '69 K20 with a 350 from an '84. I have a hodge podge of pulleys and accessories, so I am updating everthing. When I removed the crank pulley it was a heavy iron pulley with holes drilled in it for balancing. Everthing I've ever seen is just a harmonic balancer with a stamped steel pulley. My harmonic balancer also seems narrower than I remembered.
Do I have to Install a larger/thicker balancer?
Do I have to use the iron pulley or is it ok to install the new stamped steel pulley?
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 06-17-2002, 09:56 PM   #2
speeddemon
speeddemon's Avatar
Some SB 350's came with a 6in. balancer and some with a 8 in. If the engine was balanced from a machine shop they might have balanced the front pully also. If not you should not have a problem with just changing the pulley. You want to stay with the correct balancer though.
69-C10 LWB
71- fleetside shortbed
It's a shame stupidity isn't painful
Never play leapfrog with a unicorn
speeddemon is offline   Reply With Quote
Old 06-17-2002, 10:29 PM   #3
HeavyK20
HeavyK20's Avatar
If the engine was balanced with the iron pulley on, What problems will I create if I throw it away and install the stamped pulley?
Eric
