06-17-2002, 11:43 PM | #1 |
Now the others dig........
Help With Temperture Switch!!!!
On a 307, where on the exhaust manifold does the temperture switch go to. There are outlets from the manifold to the front ram horn on the steering column side and on the manifold under back ram horn on the starter side. WHERE DOES THE SWITCH GO???? On my dads 305...it is on the column side....I think thats the switch...it looks like a little nail in a spark plug looking thingy. AANNDDDD..
1-What type of wire sould be used..... 2-how do you connect the wire to the switch???? 3-what type of connector?????. 4-ALSO....where does the needle from the dash temp gauge need to be?? centered or reading cold??
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
06-17-2002, 11:50 PM | #2 |
its all about the +6 inches
I am completly confused on what your talking about here.
What are you trying to turn on/off with this switch? From what you describe, your talking about an oxygen sensor, which the only reason you should have on in your truck, is if you are delivering it to someone who needs it for there computer controlled car. |
06-18-2002, 12:17 AM | #3 |
SORRY.....
GEEEEZ MAN....i didn't make sense at all....ok here we go....
I need to know how the temp gauge from the dash connects to the engine. You know, the gauge that tells you how hot the engine is running??? I need to know how to connect that to wherever it needs to be connected so the gauge will read....thats it....please tell me how and also, before I connect the gauge.....should the needle read cold or should it be in the center.....I hope this helps...sorry...
06-18-2002, 12:45 AM | #4 |
Ok, cool I got you now.
While most temp guages will be in all the way to the left (cold) i have seen a couple of these guages function properly when they hang up in the middle turned off. All the really matters, is that is goes to the cold when you turn it on and the motor is actually cold. The wire you are looking for is a dark green wire, and it should go to the temp sending unit. Normally this will be inbetween the #1 and #3 exhaust port on the side of the head (inbetween the spark plugs) however, sometimes, for one reason or another, it may be on the intake manifold in the front center area. I am not 100% sure about teh fitting, but I am thinking it is a female spade terminal...kinda like what you would find going to a speaker inside the speaker box. |
06-18-2002, 03:53 AM | #5 |
years older than our truck has the sender unit for temp gauge in intake, it weas moved in mid 60s somewhere doiwn to driver head, forgot now what year it was, would have to look it up,.
the needle can stop and point wherever it wants to, it looses magnetic force action against or to it when key is shut off, it free floats in the gauge assembly if you ever disassembled gauges then yull know what i mean,. it can sit whereever it wants to with key off, if it pegs to hot side with key on then you got problems with the dk green wire to the sender unti in head grounded on metal soemwhere probably at firewall where it goes through or on the exh manifold. good luck |
06-18-2002, 09:18 AM | #6 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Just for reference sake.My 71 SBC 350 has the temp gauge sender threaded into the drivers side head inbetween the #1+3 cylinder.
It runs off a dark green wire.The connecting point on the temp gauge senders are what looks like a brass post with a flat ring attached to it.A female spade terminal slides over that connection on the sender(Hope that makes sense). As far as where it sits when ign off,mine usually sits where it was when it was on and goes to the cold side when ign. is turned back on if sitting long enough. Here's a pic of where my temp. gauge sits when it's warm.I run a 180deg. thermostat.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
06-18-2002, 10:02 AM | #7 |
Just to add to the other replies, the outlet on the passenger side head is for the TCS (Transmission Controlled Spark) system used for emissions control from 1970 (I think) on.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
06-18-2002, 10:09 AM | #8 |
Swingsax68,
Is your dad's 305 a later model, computer controlled vehicle? Are you sure you don't have the oxygen sensor on your dad's 305 confused for the temp sending unit? The temp sending unit is mounted in a water jacket somewhere (in the head or the intake manifold). The oxygen sensor looks like a "spark plug" and is mounted in the exhaust system in or just behind the exhaust manifold on later model, computer controlled vehicles. |
06-18-2002, 10:27 AM | #9 |
His 305 he had over hauled and put into his 78 pick up sometime in the early 80's to replace his busted 350.....the 305 valve covers look exactly like mine, they have these little peices on them that look like supports. I think it was a pre 307 engine, maybe a 305 from a 67 pick up or from a camaro. I'm not sure how old it is....but I do know what little plug you are talking about, therefore I am safe to assume that the temp switch has to have a spade connector. correct?
06-18-2002, 10:37 AM | #10 |
After I have figure out this mess, is it ok to move the needle from the temp switch to cold, or should I leave it just to see what it does????
SORRY I SEEM SO OUT OF IT......IM TRYING TO STUDY FOR A TEST WHILE I TRY TO SOLVE MY TRUCK DILEMMA!!!! ALGEBRA, NO LIKEY TRUCK, LIKEY LOTS TEMPERTURE SWITCH WORLD CUP GO USA BEST SHOWING IN 50 YEARS!!!!!
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 Last edited by SWINGSAX68; 06-18-2002 at 10:41 AM. |
06-18-2002, 12:17 PM | #11 |
if you're talking about moving the guage needle by hand, on a cold motor it should move to cold by itself when you turn the key on... if it doesn't then you still got problems... here's a pic of the plug for the temp sender...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
06-18-2002, 01:09 PM | #12 |
plug
GREAT....now I know what it looks like.....where can I find one of those plugs? Can I buy one at a parts store???? thanks...
