06-18-2002, 11:33 PM | #1 |
How to protect newly cleaned cast iron intake manifolds?
I just got it back from the machine shop from serious cleaning, and it looks brand new, so obviously I don't want it to turn into a hunk of rust. How should I protect this thing? I really don't want to paint it. I want to keep that "new" look, and preserve it. Isn't there some kind of clear coat stuff you can use?
Any suggestions? Only idea I have right now is to prime it with self-etching primer, and throw some cast iron color paint on it.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-18-2002, 11:36 PM | #2 |
I guess you could oil it.......... I dunno, your idea doesn't sound too bad.
06-19-2002, 08:59 AM | #3 |
Registered Cruiser
Cast color paint is available.
I intend to live forever. So far, so good. |
06-19-2002, 09:54 AM | #4 |
Keepin' It Stock
PJ1 makes a rattle-can clear high-temp coating for motorcycle exhausts. If it will hold up on motorcycle exhausts it should hold up on manifolds.
http://www.j-pcycles.com/shop/group....ID=29&DPID=163
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
06-19-2002, 10:09 AM | #5 |
For Cast Iron Parts i use a spray paint called Cast Coat,bottom shelf at pep boys,dont use the silvers,actually another nice color is Ralley Wheel Grey,its a paint called Steel Wheels by Duplicolor.
06-19-2002, 10:33 AM | #6 |
Not my good side.
I've used the cast coat as well, and I like it. The can says it's supposed to withstand temps up to 600 degrees.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress. 00 Suburban LT 90 Camaro RS 79 Yamaha XS1100 Special (Ol' Reliable) |
06-19-2002, 12:05 PM | #7 |
I think Cast Coat is what I ended up with from NAPA...
