Old 06-19-2002, 06:37 PM   #1
WORNBRAKES
Question gear ratio
I am in the middle of changing my rear end oil before I drive across the country. I want to figure out the rear end ratio but I need specifics on counting the teeth. This is something I have never done before and my Haynes dos't say much. Could anyone help me with this?
Thanks,
Mario
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-19-2002, 06:40 PM   #2
Super Chevy
Super Chevy's Avatar
I think you count the teeth on the ring then divide that number by the number of teeth on the pinion
.02
SC
Super Chevy is offline   Reply With Quote
Old 06-19-2002, 06:45 PM   #3
bigvinnie
bigvinnie's Avatar
yeah, what he said... like if you got 41 ring gear teeth and 11 pinion teeth, 41/11 = 3.727 or 3.73:1 ratio....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 06-19-2002, 06:57 PM   #4
WORNBRAKES
I am having a hard time seeing the pinion. Take a look.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-19-2002, 06:58 PM   #5
WORNBRAKES
here is another
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-19-2002, 07:08 PM   #6
bigvinnie
bigvinnie's Avatar
you should be able to get in there with a good light and see it from the right side.... then you can mark on it with some paint or a blob of grease, jack up one side of the axle, rotate the tire and count the teeth.... no worries
72 Stepside Project
Old 06-19-2002, 07:40 PM   #7
WORNBRAKES
I counted 41 and 10. 4:10 is what I get. 4:11 posi only right. I am going to put fluid in the truck and then change the fluid in the trailer and figure out those gears.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-19-2002, 08:05 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That would explain why you don't want to keep it at 85 MPH on the freeway. WWWAAAAAAAAAAAAAAAAA!!!! (engine sounds)
Old 06-19-2002, 08:33 PM   #9
COBALT
COBALT's Avatar
Jack the truck up in the back, and throw the transmission in neutral. Take off the emergency brake, and have someone turn the driving wheel (or any wheel if you have a locker).
While the ring and pinion are turning you should be able to see better. Heck you might be able to get in there with a wax pencil (white) and mark a tooth, and then count until you see the mark come around again.
Just some ideas.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-20-2002, 01:29 AM   #10
WORNBRAKES
Thumbs up
Thanks to all for you help. You guys are great. This was the first time I looked that close at a rear end. Well I managed to get the oil changed and figured out the rear ends in the truck and in the trailer.
Truck-4:10
Trailer-3:73
I hope that I don't find any other reason to look at them. lol I read something on an old thread about spinning the tires and counting axel rotations to figure out the ratio. Does anyone know the details on this?
Thanks,
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-20-2002, 02:35 AM   #11
WORNBRAKES
Just went out side and noticed that the rear end is leaking. I guess it dont like new oil. lol On the trailer I noticed that someone had used some type of sylicone to assist in the sealing. Does anyone have any idea of a good sylicone to use?
Thanks.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-20-2002, 03:24 AM   #12
Ed ke6bnl
silicone sealer
Thanks.
I personally like to use the high tem orange sealer for most applications. It is heavey consistancy and I have had little problem with leaks with poor mating surfaces. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 06-20-2002, 10:25 AM   #13
ckhd
ckhd's Avatar
Jack up one tire method:
1) Chock the wheels (cram rocks in front and behind so the thing doesn't roll away)
2) jack up one rear tire (duh?) DON'T FORGET the jackstand. Knowing gear ratios isn't worth killing yourself.
3) mark a spot on the tire
4) mark a spot on the drive shaft
5) put tranny in neutral
6) turn the tire TWO full revolutions while counting how many times the driveshaft spins.
7) how many times the driveshaft spins during the two tire revolutions is your gear ratio.
A touch over three turns = 3.07:1
Three and a half = 3.54:1
Three & 3/4 = 3.73:1
Just under four = 3.90:1
A touch over four = 4.11:1
Four and a half = 4.57:1
etc...
Note: This doesn't work on posi and most lockers.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 06-20-2002, 05:12 PM   #14
Longhorn Man
I don't even use the gasket. pure RTV. Never had a problem yet either.
Old 06-21-2002, 09:45 AM   #15
Kas68c10
Kas68c10's Avatar
You can check http://randysringandpinion.com[/URL] and use one of their calculators as a check also. My rear has hi temp orange silicone on it, no problems.
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
