4sd to auto
I'm switching my 72 k5 from a 4spd to an automatic. Is the transfer case the same or do I need to find another tansfer case? I'm also installing a 4" lift springs and blocks on it, what do I need to change on the front end?
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick" ~72 chev swb w/68 front clip "GM Millenium corvette yellow" I use and accept Paypal |
First thing you need to do is wrap that 4 spd up and send it my way Bernie.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
ttt
Surely someone must have this swap.
I "think" that a 4X4 turbo 350 auto will fit into that transfer case. Can't be a non-four wheel drive tranny. You'll need to install a radiator with the auto tranny cooling lines that go into it. You'll need to remove the flywheel and get a flex plate. What about linkage? Do you have an auto steering column?
If you're putting a 4" lift kit in it, then you'll need longer shocks and maybe a dropped pitman arm. There seems like a couple other things I'm forgetting too. Might need longer brake lines.
1972 Chevy 3/4 ton Camper Special 1970 Chevy big block parts truck 1989 Chevy Blazer Silverado 4X4 |
there are thre different input shafts thay i cna recall off the top of my head, 32 spline long fo rlater model 80-88, 27 spline for th350 and the 10 spline i believe,.
i thik 10 is for 68-79 4 speed searcxh on google.com for ch465 and sm465 there are a coupel pages with pics of the inputs and descriptions, ive run into them a few times, but i never save the info cuz i have no 4x4., good luck |
http://www.jeeptech.com/convtrans/gm/gmsm465id.html
http://woody.ih8mud.com/sm465.html good info here at top and bottom: http://www.advanceadapters.com/acrobat/gm.pdf manual to auto: http://www.geocities.com/spencerhut/...trans_swap.htm http://www.jeeptech.com/convtrans/convsm465.html http://www.google.com/search?q=sm465...&start=10&sa=N |
dubie.
"First thing you need to do is wrap that 4 spd up and send it my way" If you want the 4 spd set up it s yours, Although its for a 4x4 setup and I'm not sure if it will work for your application. batboy, thanks for the info, most of the parts I need to do a swap I have. I will be looking for a dropped pitman arm, so if you run across a used one or know where to find a new one let me know, thanks Fast68Chevy, I counted the splines and it turns out to be a 10 spline output shaft. The sites you posted gave me a lot of info and I think I'm probally better off finding a used 350/np205 to rebuild. Thanks for taking the time to research this for me. cheers ![]()
Suburbans RULE!
It's too bad you aren't closer.......I'd trade you all of your manual parts for all of my automatic parts. I would love to have a 4spd in my Suburban.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
