Old 06-21-2002, 10:41 AM   #1
snow man
Question gas tank
just got the gas tank back from having the leaks repaired,they put some kind of acid in it to cleand it out and now it is rusting all over on the inside.what should i put in it now to clean the rust out of it?i thought when they boiled it out it would come back clean,but it is solid surface rust. snow man
snow man is offline   Reply With Quote
Old 06-21-2002, 10:44 AM   #2
Randy70C-10
Randy70C-10's Avatar
I took my tank to a radiator shop. They cleaned and sealed it with some shiny stuff, now the inside of my tank is shiney.
Randy70C-10 is offline   Reply With Quote
Old 06-21-2002, 10:57 AM   #3
snow man
tank rust
i took this to the radiator shop but tthe acid they used took the coating off the inside of the tank and now it is all rusty.i would just like to know what to do now to get the surface rust out of it.i wish it would have come back all shiny but it didn't. how do i fix it is what i want to know.need help hear!!!!!!!!!!!! thanks snow man
Old 06-21-2002, 11:19 AM   #4
Randy70C-10
I've never seen them come back rusty. It sounds like they flushed it, but forgot to seal it. Have you called them about it?
Old 06-21-2002, 11:21 AM   #5
tom hand
CCRider
tom hand's Avatar
Try this
http://www.blast-a-way.com/faq_gastank.shtml
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-21-2002, 11:35 AM   #6
snow man
sent for catalog
thanks guess this truck going to be down for some time now.i was hoping to get it back to running this week end.
Old 06-21-2002, 12:04 PM   #7
johnnyp
Keepin' It Stock
johnnyp's Avatar
tom hand's advice is good - this is a tank sealer made by POR-15 and is good stuff. Be sure to remove the rust before sealing - their "Metal-Ready" does a good job. You can buy both direct from POR-15 at:
http://www.porstore.com/
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 06-21-2002, 12:10 PM   #8
Low69CST
I would call the people that put the acid stuff in it. Your tank shouldn't rust up like that just by sitting. If they screwed up they would probably fix it for you.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-21-2002, 12:20 PM   #9
KP1972
KP1972's Avatar
Speaking of tanks!!! I am buying a new one tomorrow. Any helpful hints? How about some help about my fuel line going from the tank under the cab to the fuel pump??? Right now it is a rubber hose with a fuel filter attached and pretty darn close to my exhaust. Is that dumb or what??? So any help about metal fuel lines would be a GREAT help!
1972 Chevy Custom/10
www.PictureTrail.com/KP1972
Metroplex Muscle Car Club
www.PictureTrail.com/DreamCarArt
KP1972 is offline   Reply With Quote
Old 06-21-2002, 12:28 PM   #10
snow man
Lightbulb tank
well i learned someting you guys got me pointed in the right direction.i have the por 15 metal ready on the shelf.i am going to call and se what they used for acid treatment,reflush an put metal ready in it until i can get the tank sealer.i think this should work till i can get the sealer in it. thanks to all of you for the help. snow man
Old 06-21-2002, 04:46 PM   #11
johnnyp
Keepin' It Stock
johnnyp's Avatar
yeah, snow man you may not need the sealer if you get the rust out first or at least you can wait until you get time/money - here's what POR-15 says:
Fuel tank sealer should be used as a last resort, and is not always necessary. Fuel tanks that are rust-free and have no pinholes or leaks may not need sealing at all. They should, however, always be kept full of fuel, which prevents condensation and further rusting. If vehicles are not used frequently, fuel tanks should be treated with POR-15 FUEL PRESERVATIVE/STABILIZER, which will keep fuel fresh for two years or more and insure quick starts even after months of non-use.
Old 06-21-2002, 07:08 PM   #12
Stepside
Gasser
If you lived closer, I'd give you mine
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
