Old 06-23-2002, 12:43 AM   #1
moose
conversion kits
Has any one used the 6lug disc brake conversion kit from GMC Paul does it come with the hub as art of the disc. thinking af ordering it the one with out the spindles.
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr
7I JIMMY 350 4speed daily driver/next prodject
99Yukon wifes
moose is offline   Reply With Quote
Old 06-23-2002, 07:18 AM   #2
GMCPaul
Moose yes the hub is a part of the rotor, these require the use of 71-87 truck 2wd spindles, or 71-91 Blazer,Jimmy Suburban 2wd spindles or using our stock height or drop spindles. They will not work on 70 or earlier stock spindles. They are available as either 5 or 6 lug 12"rotor&hub assembly, include new calipers, brake hoses, brake pads, races, seals, bearings inner&outer, spindle nuts, cotter pins, & dust caps. The 5 lug kit is great for 71-72 owners looking to redo with new all the front brake parts, besides for converting non-disc trucks to disc with the use of different spindles on 70 and earlier.
GMCPaul
GMCPaul is offline   Reply With Quote
