Old 06-23-2002, 05:13 PM   #1
shortbed70
shortbed70's Avatar
head question
When is it necessary to use screw in or studed rocker arm studs. Am i going to have any problem running .480 lift without either or??
shortbed70 is offline   Reply With Quote
Old 06-23-2002, 05:27 PM   #2
Randy70C-10
Randy70C-10's Avatar
Na, you should be OK with press in studs, as long as you don't go overboard on the valvesprings. Once you get over 500 lift and triple valve springs, then I'd think about screw-in studs.
Randy70C-10 is offline   Reply With Quote
Old 06-23-2002, 06:18 PM   #3
flyin99
creator of kong
flyin99's Avatar
What are you running........100lb. seat pressure probably?????? you will be fine without all that other, just like Randy said....you will be fine with press in studs and no pins.....
flyin99 is offline   Reply With Quote
Old 06-23-2002, 09:02 PM   #4
shortbed70
shortbed70's Avatar
i'M RUNNIN THE SPRINGS THAT COME W COMP CAMS KIT 280 H
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
Old 06-23-2002, 09:39 PM   #5
Randy70C-10
You should be fine then. That's a nice streetable cam, they have a nice lopey sound too! My buddy has that same cam in his 1946 Ford coupe (Chevy powered)
Old 06-23-2002, 11:39 PM   #6
shortbed70
shortbed70's Avatar
I just finished the motor today after yesterdays mishap ( I broke the second ring.040 and noone in town had one) so I bought a set and finished it up. Installing the roll control tomarrow. With this motor and a manuel valve body she ought to be fun to drive. Thanks for the input.
Troy
Big Red Dog build
