Old 06-27-2002, 04:49 PM   #1
steelsoldiers
equal tire balance powder??
Have any of you guys tried equal to balance your big meats? I'm always losing weights off of my 35"s and I heard this stuff might be pretty good. Any thoughts?
Thanks,
Chris
webmaster, www.steelsoldiers.com
1984 M1009 CUCV Military Blazer w/ Caddy 500 big-block and a 1970 M35A2 2.5-ton 6x6 cargo truck w/ 478ci multi-fuel straight-six engine. Both in desert tan CARC paint from Operation Desert Storm.
steelsoldiers is offline   Reply With Quote
Old 06-27-2002, 11:57 PM   #2
DINS 1
DINS 1's Avatar
I have a friend that has a set of 35x12.50x16.5 BFG mudders that have equal in them. Has helped the tires to last around 60,000 miles on a 81 k30 chevy. another friend has equal in 35x12.50x15 BFG AT's they have run in the 60,000 mile range on a 86 K5 with a diesel in it. I am going to run equal in my 35's when I get the k20 burb finished
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 06-28-2002, 01:53 AM   #3
lost wages
lost wages's Avatar
i had equal put in my 35 boggers and it was horrible, i know the tires are hard to balance but i mad em do it the old way and it was much better. Might be better on the tires like a mt.
lost wages is offline   Reply With Quote
Old 06-28-2002, 09:30 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Never had a problem with my tires or the weights coming off. My rims have a good edge for the weights to bite onto. Never heard of the equal stuff.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-08-2002, 02:29 AM   #5
LeRoy
Registered truck nut
LeRoy's Avatar
My buddy tried it in his 35x14.50x16 Swamper SSR's and didn't like them. He went back to weights. Swampers seems to be harder to balance so that may be the problem
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 07-09-2002, 02:09 PM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
we tried the equal thing in semi truck steer tires once, we found that if you don't use dry air, the powder has a tendency to stick together and turn into a big glob, totally defeating the purpose....
believe it or not, golf balls were the best thing we found to balance truck tires...just drop 3 or 4 in there and they will balance out the tire with centrifugal force.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 07-11-2002, 07:08 PM   #7
DINS 1
DINS 1's Avatar
I have equal in my 265 x 75 x 16 on my 92 burb also. i have no problems. I put a in line water filter(like you see on paint guns) on my air chuck that takes any moisture out of the air i put in my tires.
Wade
79 RS Camaro
Old 07-16-2002, 12:46 PM   #8
Mudder
Mudder's Avatar
Equal!
The trick to get this to work is keeping it dry. I wont work if moisture is present.
Mudder is offline   Reply With Quote
