Old 06-29-2002, 04:19 PM   #1
1SAWB
power steering swap
i have heard from many many people that a steering box from the 73 up will bolt right on is this true
1SAWB is offline   Reply With Quote
Old 06-30-2002, 04:23 PM   #2
Pont
I need another Barley Pop
Pont's Avatar
not sure if this is true or not. I know it won't bolt right up to a 67 or 68 frame but it might on the 69 and later. I'm using a 77 power steering box on my 67 but had to build spacers to mount the box away from the frame. If you have a 69 or later, I couldn't imagine it being to difficult at all.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 07-01-2002, 11:35 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
As long as it is a 4wd power steering gear box it will. But don't get too new or you run into different hose ends. The one I'm using is like from a 77 Chevy 4x4 and it was a simple bolt on. New hoses purchased at O'Reily's and that's all I had to do to get it going. For the power steering pump, you might have to change your crank pulley, at least I had to on my no option truck.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-08-2002, 02:19 PM   #4
ckhd
ckhd's Avatar
I put a '78(ish) blazer steering gear in my '69. Bolted right up, but the drag link wasn't the right length and I could turn really well to the right, but not so good to the left. It wouldn't bolt up to my '68 at all. The frame mounting was completely different, and so was the drag link, and the arm on the axle.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
