Old 08-24-2005, 10:49 PM   #1
David Johnson
David Johnson's Avatar
Under dash A/C question
Anyone ever heard of "Climatic Air Classic" under dash a/c's? I have one I got out of an old truck and I'm trying to make it work. I need some wiring info and knobs. Also, does anyone know if these units had a compressor on the engine? There is a black wire that goes through the firewall but I don't know what it hooks to. Thanks
David Johnson is offline   Reply With Quote
Old 08-25-2005, 08:37 AM   #2
Woogeroo
usually the under dash part was where the air blew across the evaporator - witht he fans and things - the compressor was under the hood - or that is my limited understanding.
my '65 had an aftermarket unit under the dash like that installed but the hoses goign to and from the compressor were shot so I took it out. The fans and thigns worked great...
-W
Woogeroo is offline   Reply With Quote
Old 08-25-2005, 08:44 AM   #3
60-66 Nut
Professional Beer Tester
David, I don't remember hearing that brand name, but there were/are umpteen companies making those units. It has to have a compressor to function, that should be what the black wire is for. Most of those units only needed a 12V power wire(hot with the key on) to operate. As for knobs, you might be easier just trying to match up some knobs off of something else. Best of luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 08-25-2005, 09:52 AM   #4
David Johnson
woogeroo - Do you want to sell the unit?
Old 08-26-2005, 06:54 AM   #5
Woogeroo
Smile
sure. I'm not using it.
I sent you a private message with the details... 8/27.
-W
