Old 07-02-2002, 09:09 PM   #1
OneFine99
4-Wheel Drive Conversion?
Alright, I've got a '76 Chevy c-10 long bed project truck, and I'm wanting to convert it to 4-Wheel Drive. Now, what all is involved in such a swap, and what all would I need to do this? Would it be more practical to get a 4-wheel drive frame? Or to find everythin gi need at a junk yard? My goal/plans for the truck are 12" suspension, 4" body lift, 44" boggers, 5.14's front and rear, paint it viper blue, redo the whole interior. Pretty much looking to build a HUGE weekend toy, that I could take on short trips, haul something with it, or put around town reliably. Any suggestions/ideas are greatly appreciated.
****Vanessa****
1999 Chevrolet Z-71 LS Ex. Cab
Summit White/Pewter
3" Performance Accessories Body lift
35x12.50 BFG's on 15x10 AR "Baja" series wheels
Stull Billet Grille
APC clear sidemarkers
True Dual Exhaust with Flowmaster 40 series mufflers (cats removed)
Port/Polished MAF
3.73's
Ported TB
Throttle Body Spacer
Limo Tint all the way around, 5% eyebrow across the windhield
JLAudio,PPI,Pioneer,Fultron stereo
OneFine99 is offline   Reply With Quote
Old 07-02-2002, 10:19 PM   #2
diehardrider
KEEP IT PINNED
Look for a k20 or k30. 2nd gens can be found for dime a dozen. Also the 3/4 ton running gear will be need for those boggers. I think 12 inch lift by itself will be fine. maybe a little fender trimming.
If you really want a shortbed i would still find a 4wd frame and swap in all heavy duty running gear.
diehardrider is offline   Reply With Quote
Old 07-03-2002, 01:41 AM   #3
fender
3/4 ton diffs will no be enough if you plans include anything else but driving slowly on the street. One ton running gear is mandatory for 44s if you want to wheel.
I suggest you sell the truck you have now, and try to find a 77-87 (91 if you want a crewcab) K30. The one tons already come with a dana 60 front, 14 bolt rear (dana 70 dually) which are strong enough for massive tires. The K30s also have stronger frames than the 1/2 and 3/4 tons and are less likely to crack.
it takes many nails to build a crib, but only one screw to fill
fender is offline   Reply With Quote
Old 07-03-2002, 11:38 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
That's a lot of lift and a lot of tire. I would definately suggest 1 ton running gear too. Make sure you re-enforce the frame around the steering box. You'll tear that the first time you 4x with those tires. ORD sells a kit.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-03-2002, 11:44 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Need to start with a one ton truck.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-04-2002, 10:01 PM   #6
OneFine99
Well....anyone got a one ton truck they're willin to part with for dirt cheap?
****Vanessa****
Summit White/Pewter
Stull Billet Grille
Port/Polished MAF
3.73's
Ported TB
