11-20-2005, 07:46 PM | #1 |
how do i wire my HEI?
maybe this is a stupid question, but do i need wires running to my HEI? it looks like all the possible wires have been cut so i don't think any of them go to the HEI, plus i don't have a tach so i won't need the 2 wires running to the front of it will I? so what color was the original wire that led to the coil?
also for the AC compressor, which color wires run to it? |
11-20-2005, 08:17 PM | #2 |
Designated A-hole!
Re: how do i wire my HEI?
FAQ threads on HEI
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403 http://67-72chevytrucks.com/vboard/s...ad.php?t=13698 Wiring diagrams (may help for a/c) http://67-72chevytrucks.com/vboard/s...ad.php?t=30173 The index thread where I got all this. http://67-72chevytrucks.com/vboard/s...d.php?t=157669 I hope it helps.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-20-2005, 09:52 PM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used a relay to power my HEI.Not really needed,but I'm crazy that way
Here's the thread to that install. http://67-72chevytrucks.com/vboard/s...d.php?t=105675
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
11-20-2005, 11:40 PM | #4 |
its all about the +6 inches
If you have no wires to the HEI, it won't run. All you'll need is the one power wire coming from a switched source, be it the fuse box, the bulk head, a toggle switch, or a relay.
11-21-2005, 12:20 AM | #5 |
i always knew u wasn't right longhorn an relay on your hei lol well i worst i was running the cd player in my old truck on an relay that i could cut on and off
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-21-2005, 06:26 AM | #6 |
In all reality, if you talk to the pros, they'll tell you that is THE way to go if you are lookin for power.
11-21-2005, 05:39 PM | #7 |
hmm, thanks so far. i have a red wire coming from a bundle, and it splits into 2 yellow wires, and the p/o had a female spade connector on 1 of the yellow wires. that's the one i hook to the HEI right?
edit, nevermind that, i looked at some before pictures of my engine bay, and there was the exact wire i just talked about. |
11-21-2005, 05:47 PM | #8 |
Questionable
I explain how to rewire for HEI in this thread, which is in the index thread that krue linked above:
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-21-2005, 06:12 PM | #9 |
yea i know where the faq section is, but the biggest problem i had was where the wire went on the distributor, that is after i found out which wire it was.
11-21-2005, 09:49 PM | #10 |
Questionable
Are you not looking at the same post as me? I just linked one with pictures to everything you're asking. Look at this one single post in particular:
http://67-72chevytrucks.com/vboard/s...21&postcount=8 There are many more pictures in the thread which show how it's hooked up. Just make sure your pink wire connects to the tab attached to the red coil wire (this is assuming you have the correct wiring, I show how to wire from the firewall to the dizzy in that thread also). If you're ever in question, look at the post that follows it. It's right here, I'm not sure how you missed it: http://67-72chevytrucks.com/vboard/s...24&postcount=9 Notice the writing on top of the cap. It tells you exactly what wires go where also. They make it pretty dummy proof
11-21-2005, 11:53 PM | #11 |
yea, i mean i figured everything out now, all is good. i mainly needed to know what wire and how to connect it and now i know. that's what i meant with "the biggest problem i had was".
11-22-2005, 12:07 AM | #12 |
longhorn forget i called u crazy i got yours and BobbyK's post confused
11-22-2005, 12:30 AM | #13 |
Questionable
Sorry dude, I think I missed your tense.
11-22-2005, 06:35 AM | #14 |
well... mine is wired through a relay too, so if the shoe fits...
Besides, we all know I got a little crazy in me. |
12-05-2005, 12:29 AM | #15 |
So, if you run it through a relay, you can use the factory resistance wire to energize the relay coil right? What is the "run" voltage on this wire? As long as it is above 9 volts, and can handle 200mA, it should fire a 12v coil.
This would simplify the wiring as well as deliver all the current the HEI needs. I have to put an HEI in the UPS truck tomorrow, as the points have gone south for the winter and I flooded the living crap out of it today. New plugs, HEI, and wires....all is good. Thanks.....Bill |
12-05-2005, 12:38 AM | #16 |
you could use the resistance wire... I think it is at 9 volts... It'll run the HEI, but I'll bet you my next paycheck AND a kick in the daddy parts that you'll FEEL the differance from HEI on resistance wire, and HEI on 12 volts.
12-05-2005, 01:43 AM | #17 |
No, I was going to trip the relay with the resistance wire and supply the HEI with full 12 volts.
I wired Screamin's HEI through the fuse box to a keyed 12v supply, but I like the idea of using a relay to power it up as well, and if it helps with performance/economy I am all for it. |
12-05-2005, 02:04 AM | #18 |
Something like this...
12-05-2005, 05:50 AM | #19 |
my fault, I read that wrong.
12-05-2005, 01:35 PM | #20 |
Questionable
That would be a reasonable way to run it, but I think your relay would need to be able to still throw the internal switch @ 9v constant power. I thought all relays were 12v relays?
Do some research on that one before you embark. Tucking the BATT wire on that one should be a blast
12-05-2005, 01:51 PM | #21 |
I did this on an old jeep. I used the 9V wire to kick a relay for the 12V power wire to the HEI.
Was slick and allowed me to go back to stock if needed. |
12-21-2005, 05:15 PM | #22 |
hey
i am putting in a motor that has hei but also has the 4 pin flat connector. I was thinking i could buy new inners for the hei that didnt have the 4 pin connector and install it. U think it would work? cheers shawn
I will run u over for FREE!!! 2001 F350 6" Lifted Dually 1970 ScoutII with chevy implants 1970 GMC 3/4 LB 4x4 (for sale) 1972 Chevy 3/4 LB 4x4 -project |
12-21-2005, 05:50 PM | #23 |
The distributor bodies should be the same casting. You will have to replace the module, the mechanical advance mechanism, the vac advance mechanism and the pick-up coil. Not worth it when you can pick up a complete drop in unit for under $75.00
Just my $.02 |
12-21-2005, 05:52 PM | #24 |
By the way, I converted the UPS truck to HEI last week and wired it up with a relay like we discussed up top. Worked out great once I remembered which way the distributor rotation was
Did ya know a 454 will run on 3.5 cylinders? Merry Christmas yall. |
