Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-18-2005, 07:46 PM   #1
Striker169
Car O'Holic
Striker169's Avatar
Speaker/Sub Box
So I dont have an in cab gas tank, and was thinking of building a box for two 6x9's and a 8in sub that looks and is similar to the same measurements as the gas tank. Has anyone done this before or something similar? and if you have a nice sound system in your truck could you post pictures.
Striker169 is offline   Reply With Quote
Old 12-18-2005, 08:31 PM   #2
pissonNOS
senior member
pissonNOS's Avatar
Re: Speaker/Sub Box
might I suggest getting an 8 inch cerwin vega and building the sub box the whole length of the cab and porting it then putting ur 6x9's under the seat that little 8 in a box that size ported should be plenty of boom to get out and sand if u had ur truck sandblasted haha
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-18-2005, 11:02 PM   #3
dinnut
dinnut's Avatar
Re: Speaker/Sub Box
heres my suggestion... put a pioneer premier thin series 12 in the middle of the box taking up about 3/4 of the box... seal the sub up.... so make the box have 3 chambers...and put the 6x9's on the outside maybe more toward the corners of the cab face them out a little bit maybe... maybe put some ports by the sub like shown...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-19-2005, 12:34 AM   #4
muddpile
muddpile's Avatar
Re: Speaker/Sub Box
I'd put the 6x9's out in front of the seat in the doors or kicks or something. You'll never hear the mids/highs trying to fire them through seat foam.
muddpile is offline   Reply With Quote
Old 12-19-2005, 02:25 AM   #5
72str8flush
72str8flush's Avatar
Re: Speaker/Sub Box
I agree... only way you would want to put anything other than a sub behind the seat is if it is facing up some how. I had an old truck box that was an 8 facing front and a 4' facing up and it sounded pretty good.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 12-25-2005, 05:03 PM   #6
brad juan
Re: Speaker/Sub Box
I had 2 10" kickers behing the seat and 6x9's in the doors, sounded great, I dont think you will hear the mids and high if you put the 6x9's behind the seat, the sub will be a little more over powering than the 6x9.
1972 chevy C/10, with factory air, SWB, 350,700r4, lowered 3 and 5.
brad juan is offline   Reply With Quote
Old 12-25-2005, 05:14 PM   #7
shifty
Questionable
shifty's Avatar
Re: Speaker/Sub Box
brad juan is right - highs and mids reflect - low end bass is non-directional. If you put something in front of a midrange or tweeter, will muffle the sound. It's almost impossible to muffle bass.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 12-26-2005, 12:13 AM   #8
BowTieMan
BowTieMan's Avatar
Re: Speaker/Sub Box
How would one 10 ported and componets behind the seat, 6.5" door speakers, and the tweeters from the components in the dash sound? I listen to alot of rock so I dont want booming bass, I want something thats loud with nice highs and can go with a fast beat.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 12-26-2005, 12:33 AM   #9
shifty
Questionable
shifty's Avatar
Re: Speaker/Sub Box
Ported enclosures are great for hitting low, low lows (depends on how the box is tuned). Ported boxes are finicky, unless you understand how to tune a port, build a ported box, port length and all that other stuff, I'd go sealed - it's all around easier.
I don't understand why you'd want to split the components the way you're talking about doing it. You're talking about a lot of weirdness on the wiring and stuff - if you put the components in the box, you'll need to install the crossover that comes with them somewhere...and you're gonna be running a lot of wire to join that crossover with the tweeters in the dash...
If you wanted a prime setup and you insisted on using something like you're talking about, I would go with the 10" sub in the rear, sealed box, if you must have something for mid-bass, drop some 6.5" woofers in the rear along with the 10" sub (in separate sealed enclosures or something). Get some kick panels for your components to mount them next to your feet and drop some tweeters in the dash if you really want some highs or go with a single center channel in the stock speaker location. It all depends on your budget.
If given the choice between using a coaxial or triaxial speaker or a set of components, I would pick the components hands down every time. I am very concious of having too many speakers too
Always remember - you can tweak down or up the bass using the gain control on your amplifier...so don't let "too much bass" influence your choice. With some tuning, you'll get what you want - nothing sounds perfect right off the bat.
Old 12-26-2005, 12:38 AM   #10
BowTieMan
BowTieMan's Avatar
Re: Speaker/Sub Box
So do you think one 10 sealed with about 250 watts going to it would be enough to fill the cab of a truck. Or would 2 10's be better?
Old 12-26-2005, 12:44 AM   #11
muddpile
muddpile's Avatar
Re: Speaker/Sub Box
I'm going to be running a pair of Eclipse 4 way 6x9's in the doors off a 50x2 amp. They had kind of harsh mids and highs, so they will work good in the lower door with the distance to my ears. I will also be running a downfiring alpine Type R 10" in a custom center console off 350 watts. Should be pretty loud, and still sound great. 250 to a single 10" would sound fine as well Bowtieman.
Old 12-26-2005, 12:49 AM   #12
sickred72
Re: Speaker/Sub Box
i have already done it twice 2 10" alpine type R's and 1000 watt alpine amp seald and it hits hard.......jerald
sickred72 is offline   Reply With Quote
Old 12-26-2005, 01:52 AM   #13
Striker169
Car O'Holic
Striker169's Avatar
Re: Speaker/Sub Box
sickred72 do you have anymore pictures of your setup?
Old 12-26-2005, 08:30 AM   #14
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Speaker/Sub Box
yes pleasae. more pics
Rich
1972 K5 Blazer CST Click HERE
Old 12-26-2005, 09:14 AM   #15
truckdude239
truckdude239's Avatar
Re: Speaker/Sub Box
more pictures
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-26-2005, 12:31 PM   #16
sickred72
Re: Speaker/Sub Box
e-mail me a sickred72@yahoo.com and i will give you all the pics you want. or someone tell me how to post pics they keep telling me my pictures are to big.....jerald
Old 12-26-2005, 12:44 PM   #17
Striker169
Car O'Holic
Striker169's Avatar
Re: Speaker/Sub Box
See my sig, register, and then you just click upload and browse for the file and hit the uplod button it even formats it to where you can copy and paste into the forum without having to edit the tags or anything.
Old 12-26-2005, 03:27 PM   #18
BowTieMan
BowTieMan's Avatar
Re: Speaker/Sub Box
I have a few pictures of different set up's.
Old 12-26-2005, 05:20 PM   #19
BowTieMan
BowTieMan's Avatar
Re: Speaker/Sub Box
This is a board members. If you this is yours or know whos it is some dementions on these boxes would be greatly, greatly appreciated.
Old 12-26-2005, 08:26 PM   #20
longnlow72
longnlow72's Avatar
Re: Speaker/Sub Box
thats mine, I tried to draw it out on paint just now, i didnt really have plannes laid out before hand but luckily my trucks torn apart so i measured the box, i know its confusing but ask anything u want
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 12-26-2005, 09:08 PM   #21
shifty
Questionable
shifty's Avatar
Re: Speaker/Sub Box
One ten should suffice, IMO.
I had one dual-voicecoil 12" in my extended cab '03 sierra with a 500-watt amp hooked up to it (tuned way down) and it kicked serious ass. Felt like a sledgehammer behind my seat (it was under the rear seat - a JL Audio stealthbox)
Old 12-26-2005, 10:32 PM   #22
sickred72
Re: Speaker/Sub Box
hope you guys like!!!!
thanks to all that e-mailed im no pro just kinda doin my own thing!!!!!
Old 12-26-2005, 10:36 PM   #23
sickred72
Re: Speaker/Sub Box
you aint seen nothin yet i have been building a 72 2wd blazer 20" wheels, 373 stroker, 308 posi, 700r4, $6500.00 in airride technologies airbags, tubular upper/lower control arms, notched frame, polished stainless 4 link, 4 wheel disc brakes and EVERYTHING powder coated!!!!!.......thanks jerald
Old 12-26-2005, 11:13 PM   #24
smbrouss70
smbrouss70's Avatar
Re: Speaker/Sub Box
Forum Rules - You must provide Pics!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-26-2005, 11:19 PM   #25
Striker169
Car O'Holic
Striker169's Avatar
Re: Speaker/Sub Box
QFT
