Old 04-17-2002, 01:09 PM   #1
71Chev
71Chev's Avatar
Post Header Collector Gasket ?'s
Gonna replace my header gaskets at the collectors.
Are the new copper or aluminum type as good as I hear?
Which is better, copper or aluminum?
  • 71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 04-17-2002, 01:46 PM   #2
69 longhorn
Post
I tryed the copper,& didnt like them(the ring seemed to distort the flanges when tightened up). I just have the Hooker gaskets now,but am thinking about trying aluminum......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-17-2002, 01:54 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Thumbs up
I have the aluminum ones on mine and will NEVER use anything else.
When I bought them, i had cheap nasty warped headers, they did the trick when the paper wouldn't. I have been running the same ones since '98, and have disconnected the headers countless times. I even put them on another set of headers all together. Still, no leaks.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-17-2002, 02:01 PM   #4
71Chev
71Chev's Avatar
Post
My collector flanges already have the bent together problem from when the previous owner installed the headers then over tightened the collector flanges. Now they are leaking.
Can I beat the flanges back some and still use aluminum gaskets?
The aluminum appear to be more of a thick spacer, correct?
Old 04-17-2002, 02:13 PM   #5
Longhorn Man
Post
It is kind of a spacer, but more like a gasket. Picture the real thick gasket you always find under a stock quadrajet.
Old 04-17-2002, 02:22 PM   #6
71Chev
71Chev's Avatar
Post
Thanks Andrew.
I'm goin up to "ach cough" summit this afternoon and get the aluminum collector gaskets. and put them in this afternoon.
Old 04-17-2002, 08:12 PM   #7
71Chev
71Chev's Avatar
Post
Thanks longhorn guys. Used the aluminum, no more leak.
Old 04-17-2002, 08:18 PM   #8
69 longhorn
Post
Good deal,I will go that way next time. I guess as long as the paper gaskets are holding ,I can spend the cash on something else.....gas,the longhorn has a little drinkin prob!.........69
Old 04-17-2002, 08:22 PM   #9
71Chev
71Chev's Avatar
Post
I bought "ack cough" Summits aluminum gasket set. $9.95
The old paper ones dropped out in 3 pieces when I romoved the bolts.
Old 04-17-2002, 09:44 PM   #10
Longhorn Man
Post
Yup, that's how it normally goes. You got a d@mn good price there too.
You gotta figure if a cheap b@stard like me is using $25 collector gaskets, they must be worth it.
[This message has been edited by longhornmail (edited April 17, 2002).]
